The FIAT Forum
Old 21-12-2004   #1
burgernchips's Avatar
Trader Rating: (0)
Uno handbrake
Any one ever had the handbrake explode on you? i have the push button pinged out along with the spring, and the handbrake became unusable..
i never worked out y it did that
look in to my eyes, yes my eyes, not around them, in them *click* ure under...
burgernchips is offline
Old 21-12-2004   #2
Moderator
Trader Rating: (7)
Steven has donated!
Re: Uno handbrake
Sounds like a broken cable.
Steven is offline
Old 22-12-2004   #3
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Uno handbrake
I don't think a broken cable can do this, the lever is quite a self-contained assembly. It moves through a quadrant with a spring-loaded ratchet that never allows the knob to 'come flying out'. So the most likely failure in my opinion must be the ratchet itself. May as well get another lever off a scrapped car, they are not a common failure. But you will have to take out the seats and carpet. Before the seats will slide out (rearwards) you have to hammer-in the tabs inside the seat rails.
While you are there, you can improve the lever as follows.
Unbolt the bracket from the floor (two bolts). You will probably find that the captive nuts have torn away from the floor.
Take out the pivot pin (thin clip in the shape of a ring with a break in it)
Push in one or two thin washers so that the lever is a tight but smooth fit in the bracket. Grease it, and put the pivot pin back in.
Get two thick washers about 3-4cm in diameter with an 8mm hole, also two 13mm (across flats) nuts and some longer bolts to match.
Install washers under reinforcements in bodywork seemingly intended for the purpose, yet not used (the sheet metal with captive nuts sits on top of the reinforcements instead of underneath!)
Get an assistant to help with fitting the lever bracket with bolts through the thick washers.
My handbrake lever feels 100% better and no welding etc. was required. In the past I have added extra tabs to the lever bracket (in standard form, the tabs are optimised for left-hand-drive). But now, I don't think it's worth the trouble. Just add the washers (you should even be able to get the plastic cover refitted reasonably well underneath).
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 22-12-2004   #4
alexGS's Avatar
Trader Rating: (1)
Re: Uno handbrake
Actually Burgernchips, to answer your question, I have had the knob ping out, but only once I'd removed the lever pivot pin. The knob rod has a hook at the end - perhaps this has un-bent, or perhaps the pivot pin fell out somehow?
-Alex
alexGS is offline
Old 22-12-2004   #5
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: Uno handbrake
-Alex
But do not hammer them in so you can´t get them out again. Put a small screwdriver in between before pushing them in so there´s a little glitch (or any correct describing word). Before reinstalling seats they can be bent out again, kick (I did) the seat in place past the tabs, and tam-tam-taaa seats in place.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
(T) Handbrake Mystery Solved Liam Cinquecento / Seicento 22 28-04-2008 19:13
(G) What age Uno do you drive? Mk1 or Mk2? 1986Uno45S Uno 42 20-12-2007 18:59
(G) Uno red paint colour alexGS Uno 3 20-07-2004 17:50
(T) Handbrake won't go on! SnowBord Cinquecento / Seicento 4 16-04-2004 01:15
