The FIAT Forum
Old 21-12-2004   #1
davethetekkie's Avatar
Trader Rating: (0)
Exclamation Uno Headlamp Stick...
Hi peeps...
WAY back in october I invested in my second car (well... the first to be in my name anyhoo...) which is a 1991 Uno 45s with a 999cc FIRE engine... within ten seconds of getting into the car I had broken something... but I can't see it being a totally difficult thing to fix... the head lamp stick... just to figure it out I went thru all the controls before setting off... sidelights, headlights, full beams... but I tried twisting the control off while the full beams were on and now I can't turn the lights off! I can get headlights or sidelights, both work normally, but for the life of me I can't get them to turn off!!!
So... do I need to get a new switch for it or can it be fixed?
Dave.
1991 'J' Registered Fiat Uno 45s 999cc 'Fire' (AKA PJ) (deceased 28/1/2005)
1994 'L' Registered Fiat Uno Mambo 1.0IE (AKA Lita) (Traded 16/3/2005)
1999 'T' Registered Fiat Punto 60SX (AKA Squeaky) (Backended by CHAV 26/3/2006)
1998 'S' Registered Fiat Punto 60S (AKA Rosie)
davethetekkie is offline
Old 21-12-2004   #2
Trader Rating: (1)
Luke has donated!
Re: Uno Headlamp Stick...
Originally Posted by davethetekkie
Hi peeps...
Dave.
You'll probably find you've broken the contacts on the last turn of the switch, in which case it'd probably need replacing.
If you didnt want to pay a fortune, get under the dash and find the wire which switches to the lights relay - then stick a normal push switch inbetween it. That way you can control the on off with the switch, then operate the intensity with the proper dial.
I have teh same year and model uno as you so the wire you'd be looking for is yellow. youd need to unscrew the 3 screws under the stearing wheel, then undo a final screw and bolt on the bottom plate above the pedals. You'll then have easy access to the whole loom which makes things easy.
Luke is offline
Old 21-12-2004   #3
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
There is some sort of interlock, isn't there, that prevents the switch being twisted to 'off' unless the headlight lever is in the 'dipped' position (and likewise, the lever cannot be moved to 'main beam' unless the switch is twisted 'on'?) Sorry if you have already found this!
I would have a shot at taking the switch apart, personally, as perhaps the various plastic bits just need to be popped back together correctly.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 21-12-2004   #4
Moderator
Trader Rating: (7)
Steven has donated!
It's a common problem this on Unos. It happened to mine as well. Check eBay for a used switch unit. I got one for a fiver.
Steven is offline
Old 21-12-2004   #5
Trader Rating: (0)
Talking Re: Uno Headlamp Stick...
well I had considered buying a switch for it and cutting it off... seems the best short term solution... the description of the cable I'm lookin for is good... I like the Haynes manual for all but the wiring diagrams
Old 21-12-2004   #6
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Maybe you've got a Norwegian switch unit. It is not allowed to drive without lights at all, so turning lights off is impossible. Both back and front...
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 04-01-2005   #7
Trader Rating: (0)
Wink Re: Uno Headlamp Stick...
nah mate... I'm fairly sure I've just stuffed it up... I'm a bit clumsy like that... does anyone know how difficult the switch is to replce once I've gotten the covers off the steering column? PLEASE tell me there's no soldering involved!!!
(G) What age Uno do you drive? Mk1 or Mk2? 1986Uno45S Uno 42 20-12-2007 18:59
(G) Uno red paint colour alexGS Uno 3 20-07-2004 17:50
(G) Uno 1.1 Mods Decided Mmacken2004 Uno 7 23-04-2004 16:51
(G) Gear stick adaptors, what they do arc Cinquecento / Seicento 17 06-11-2003 05:51
