The FIAT Forum
Old 20-12-2004   #1
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Temperature sensor.
Hei.
I do not know what is going on but the car doesn´t heat up properly. It get worse every week. The temp sensor now only goes 1/4 up, just between 60 and (propably) 100 degrees C. The fan also cuts in before it reaches 100 when idling.
Any known symptoms? The mechanic gadget (thermostat) which controls coolant to let in / out of the engine was replaced last year due to similiar symptoms. It was a genuine Fiat part. But now i think it could just be an error in the signal sent to the dash. Is there a temperature measure "thing" somewhere that may fail?
The car gets hot inside...
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 20-12-2004   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Temperature sensor.
could be thermostat again not fully opening, fiat ones dont seem to last long, replace it with an after market one.
Binki
dave is offline
(T) Temperature Sensor joel Punto 5 05-08-2006 13:51
(T) Sei downpipe and lambda sensor. GeX Cinquecento / Seicento 3 08-09-2004 00:43
(T) Marea external temperature sensor scanny Marea 2 30-04-2004 04:13
Sensor resistance gtomas Tipo 2 15-11-2003 06:36
(T) where is Temperature sensor on the SportingMk2 bazzasmithkins Punto 15 12-11-2003 19:40
