The FIAT Forum
Old 15-12-2004   #1
Trader Rating: (0)
Difference between mk1 & mk2 Turbo?
As the title, what are the differences (engine/turbo wise) between the mk1 and mk2 uno turbo's?
And out of the 2 which is the best/safest/easiest to get power out of?
Steve
Mk1 Punto 75sx
Mk1 Punto GT2
BlackBeast is offline
Old 15-12-2004   #2
3rd Gear Spins Anyone?
Trader Rating: (2)
Dunc Uno Turbo has donated! United Kingdom
Re: Difference between mk1 & mk2 Turbo?
alright mate, the mk1 is a 1.3 and the mk2 is a 1.4 and is almost the same engine as ur punto gt. the turbos are both T2 in mk1 and mk2 but the mk1 turbos are made by IHI and the mk2 turbos are garrett. the mk1 block is meant to be a little bit stronger but as for modifying them, both engines are fairly simlar to modify. the mk2 1.4 engine tho has a much much better gear box with a taller 5th gear and is capable of highter top speeds. over all i'd get a mk2 as the interiors of these are nicer and the look of the car is nicer (in my opinion) and the engine is slightly more modern and u'll know the engine better having owned (or own) a punto gt.
hope this helps
Dunc
Dunc
Uno Turbo i.e
Uno 1.0 (Will be given a turbo lump soon)
Fabia VRS
S14a 200sx - R.I.P
Dunc Uno Turbo is offline
Old 15-12-2004   #3
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Dunc, I thought your Uno Turbo was silver/grey
What model Punto is that?
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 15-12-2004   #4
Trader Rating: (2)
nope, never owned a grey/silver uno turbo, only this green one. the punto is my girlfrieds 1.2 8v active sport with abarth sideskirts and abarth rear spoiler. ive added a front splitter since photo, a sunstrip, sub and done a few more little bits. got lowering springs for it too but not got round to fitting them
Dunc
p.s. back to topic hehe
Uno Turbo i.e
Fabia VRS
S14a 200sx - R.I.P
Old 15-12-2004   #5
Trader Rating: (0)
Thanks for the info Dunc! Another question though, does the mk2 have a smaller gearbox casing and inlet manifold to a Punto GT?
Im asking all these questions as im very much considering putting a UT/GT engine in a cinquecento sporting and i need as much info as possible as i know there will be quite a bit of hammering/cutting/welding needed to be done!
Mk1 Punto 75sx
Mk1 Punto GT2
Old 15-12-2004   #6
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
I would uprate the brakes on that cinquecento...
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 16-12-2004   #7
Trader Rating: (0)
I would be using the GT brake set up except for ABS! So master and slave aswell as discs all round, vented upfront and solids in the rear! Most likely, uprated discs and pads all round aswell uprated brake fluid!
Mk1 Punto 75sx
Mk1 Punto GT2
(G) max speed of Uno Turbo MK1 1.3 kpematop Uno 17 17-12-2005 07:25
(G) tuning mods for fiat uno turbo mk2 Dunc Uno Turbo Uno 5 10-12-2004 15:50
(G) misfire/loss of power with my uno turbo mk1 coolhand_mike Uno 5 20-11-2004 01:05
(T) Turbo Kit Mk2 16v bazzasmithkins Punto 0 12-11-2003 19:58
Bravo Abarth side skirts: fit both MK1 and MK2? MpDay Lets Talk FIAT 7 28-07-2003 00:08
