| Couple of months ago swithc which operates vertical beam of headlights stopped to respond. It turns around but headlights doesn`t move. i noticed that there is a fluid at the end of hose where it enters in to headlight?. Can it be repaired or I need new headlight?
| | #2 | |||
| Back once again w'the... | Re: how to fix hidraulic adjustments of headlights Could you please confirm - is this for an Uno? I haven't seen an Uno myself with such sophistication. If not an Uno, you'll get the best response by posting in the model-specific forum. Sorry if this is unwanted advice, I just couldn't see how many posts you'd made before so thought I'd mention it. Thanks, -Alex
| | #3 | ||
| Re: how to fix hidraulic adjustments of headlights Yes it is about UNO mk II from 1998. (made in Poland).
| | #4 | ||
| Moderator | Re: how to fix hidraulic adjustments of headlights Unos in the UK didn't have this feature.
| | #6 | ||
| Now hacking in PHP | Re: how to fix hidraulic adjustments of headlights Just a question... Is the polish UNO the same model as the UK uno, perhaps they are a different model over here? | ||
| | #7 | ||
| Re: how to fix hidraulic adjustments of headlights Well, as far as I compared to Haynes manual there are some differences to Italian version of Uno mkII but more cosmetic then mechanic, and I will check that section in manual about headlights is there that part attached to headlights? And question to all users of Uno mkII : How do you regulate beam of your headlights? Do you have button down right from steering wheel where you regulate headlights?
__________________ JABBA THE HUT | |||
| | reivax_dj | Marea | 4 | 31-08-2008 21:35 |
| | Punto Mad | Punto | 4 | 18-11-2004 02:10 |
| | Gordon | Bravo / Brava | 2 | 31-12-2003 02:16 |
| | rob88 | Cinquecento / Seicento | 1 | 03-12-2003 18:29 |
| | syphon123 | Cinquecento / Seicento | 1 | 03-02-2003 05:26 |
