| Hello once again. I recently had the well known problem with the distributor that when the engine warms up the engine stops. I took it to the mechanic and changed the distributor for tow weeks the car was running fine lately I face a similar problem but even when the engine is cool. any advice is always wellcomed
| Back once again w'the... | Re: uno 999cc fire engine stopps Just an idea, take the top off the carburettor (10mm spanner and screwdriver required) and check that it has petrol in it when the engine stops. Otherwise it is probably that nasty electronic module on the distributor. Perhaps you should try changing the coil. There aren't many other things it could be! -Alex
| | #3 | ||
| :) | Re: uno 999cc fire engine stopps It was the vacuum advance unit on mine.
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #4 | ||
| Re: uno 999cc fire engine stopps Dear Fiat uno people. I just returned from my mechanic who i think he hasn't got a clu of whats wrong with my car. as i said on the previous post i have the problem that when the engine is warm it stalls. this hapens only when the engine is warm. When i took it to the mechanic he changed the distributor with a second hand one the original distibutor had a new vacuum. For one week the engine was running fine but whith a bit loss of power after a week the idle speed started to sound dogy and after few days it started having the same problem. i took it again to the mechanic and he changed the coil this time. the power came back but the car still stalls when its warm, maybe not that often but it does. I dont know my mechanic is useless (but he is cheap) so i need your help
| | #5 | ||
| Moderator | Re: uno 999cc fire engine stopps Find a new mechanic!
| | #6 | ||
| Re: uno 999cc fire engine stopps Hello there again and Merry christmas to everybody Ho Ho Ho I still have this nasty problem with my uno i have been to twwo different mechanics the firs one told me that is the ECU the second told me that is the single point injection system. Ant ideas?
| | #7 | |||||
I cant say ive experienced your problems with mine but do have problems with the cold (icing occurs in the carb - even with teh heat tube added), plus i have a crap vacuum advance unit (the hose just has it blocked with a screw).I think your best bet is to do what alex said earlier, check your carb is functioning fine under heat
| | #8 | ||
| :) | Re: uno 999cc fire engine stopps Luke, if it is the 999cc i.e. fire engine then it does, it has Bosch-monotronic SPI (with a throttle body instead of a carb) and a nice ECU underneath the drivers dash.
| | #9 | |||||
In that case my advice is scrap the engine to the standard 999cc FIRE, cos it dont have the problem
| | #10 | ||
| Re: uno 999cc fire engine stopps Well if I say that the mechanic said that it might be the injection or the ecu so probably it has there is no need to mention it. Another theory that somebody told me is that it might be the lamda sensor, the ting is that when i press the accelerator a bit so i increase the idle speed the engine doesnt cut off. I an thinking to take it to a fiat dealer to just diagnost it but they will charge me to much
| 999cc fire mpi? | smokeme | Lets Talk FIAT | 8 | 11-05-2005 16:08 |
| | JirKA.Pr | Uno | 4 | 16-02-2004 11:50 |
| | stash | Uno | 1 | 08-02-2004 21:46 |
