The FIAT Forum
Old 27-11-2004   #1
F R O S T Y's Avatar
Trader Rating: (0)
HELP! My Indicators dont work :(
Well as the title says my indicators have stopped working completely all of a sudden. I have checked all the bulbs and connections which all work fine, e.g if i press my remote to lock the doors all the indicator lights flash up as normal however only if i try and use my indicators whilst driving for example they do not work at all. Which has left me baffled. I have checked all my fuses which are fine so what else could it be? And also my hazard lights are not working properly either. if i switch them on they stay lit rather then flash intermittently. Someone suggested it may be the relay but if so where would it be found? My uno is a 1.4 turbo i.e but was originally a 1 litre uno i.e and still uses the switch gear off the 1 litre uno so it would be the same as a standard 1 litre uno. Everything else on the car is off a fiat uno turbo. Where would the relay be found on a 1 litre uno??? Any ideas. oh and my uno is a k reg 1993 model if it helps!
F R O $ T Y
"It Don't Matter if you win by an inch..or a mile...
Winning is Winning"
F R O S T Y is offline
Old 27-11-2004   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: HELP! My Indicators dont work :(
its flasher relay i reckon
Binki
dave is offline
Old 28-11-2004   #3
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Hi Frosty,
Take off the steering column covers (two or is it four long screws underneath, plus one in the centre).
The flasher unit is plugged in on the left side of the column switch - try jiggling it around. Spray some contact cleaner in the socket. If it's not coming to life, try to borrow one off someone before you plump for a replacement - they don't fail often so second-hand is probably best.
Refit the steering column top cover carefully - it has two little hooks at the back.
Cheers,
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 28-11-2004   #4
Trader Rating: (0)
Cheers Alex, but i dont even know what it looks like, what should i be looking out for, if u could describe it or have a pic that would help loadz. Electrics are really not my thing mate!
F R O $ T Y
Winning is Winning"
Old 29-11-2004   #5
alexGS's Avatar
Trader Rating: (1)
Frosty,
Oooh, a picture! That's asking a lot, lucky that my red Uno's in bits
-Alex
alexGS is offline
Old 28-12-2004   #6
Trader Rating: (0)
I have exactly the same problem as the original poster (indicators and hazard lights don't flash any more, when they were working fine yesterday). I have a 1995 Fiat Uno ie start.
I tried to look for the flasher unit in the steering column, to see if cleaning it would fix the problem, but I can't even get the steering column cover off. It is held on by things that look like screws, except they have flat heads, so a screwdrive won't grip them, so you can't unscrew the things.
Does anyone know how I can get the steering column cover off so I can look for the flasher unit? Or will have have to take my car to a garage to get it fixed?
Thanks,
Helen.
hmlf is offline
Old 29-12-2004   #7
Trader Rating: (0)
The steering column plastic is held together with hex bolts, u need a torque wrench to open them. Its easiest with those screw driver style ones where you can change the top head. Cant remember exact size though but if you get a set you should have no trouble opening them. I would suggest you take a look in the haynes manual for a more detailed description. With regards to the relay it should be there in the steering column unlike mines which wasnt because my car is a conversion from a 1 litre to an uno turbo so i had to hunt down the relay lol but i found it in the end and its really not too difficult to fix. Simple swap really, got a used one from a scrappy, took the old one out and replaced it with the second hand one and hey presto good as new.
F R O S T Y
Winning is Winning"
(T) How ican make it work?! Bravoholic Bravo / Brava 3 14-09-2004 17:47
(S) New Indicators - Black Ovals Cinq_Sport_BiG_DaVE Cinquecento / Seicento 13 13-09-2004 09:52
(T) Steering wheel - will it work in a Bravo? Ozric-Al Marea 5 03-09-2004 23:14
work + nice weather + going out = me dead! arc Leisure Lounge 32 02-08-2004 03:30
(T) Flashing Indicators & Warranty Tashy Stilo 12 25-11-2003 02:45
