The FIAT Forum
Old 21-11-2004   #1
Trader Rating: (0)
Gears
Hi all,
I have a Fiat Uno Fire 45 and I'm currently having what seems to be a serious problem.
When the engine is turned off, the gears change nice and smoothly, but when its turned on, first refuses to go in, second puts up quite a fight, third and reverse grind like there's no tomorrow and fourth sometimes grinds but usually no problem.
I'm taking it to a mechanic tomorrow and was just wondering if there are any suggestions as to what it might be so I know if the mechanic is taking me for a ride.
Thanks for your help
People who think they know everything are a great annoyance to those of us who do.
Deitel is offline
Old 22-11-2004   #2
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Gears
Deitel,
Sounds less like the gears and more like a clutch problem.
However, make sure that the gearbox is filled with the correct type of oil - 90-grade gear oil without EP additive. The commonly-available '5-speed transmission oil' will be correct (75W80, etc) if you cannot get the original FIAT ZC90.
A common cause for oil loss is the driveshaft boots - they have to seal onto the driveshaft as it swings around, not the best design ever.
The clutch - make sure that the pedal is about level with the brake pedal. There are exact measurements, but in my experience if the clutch cable is adjusted so that the clutch and brake pedals are in line, that leaves the clutch adjusted about right.
If you have a hydraulic clutch (no cable on top of gearbox) then you have another potential cause of problems. Your mechanic should try bleeding the system, but in all honesty it probably needs a replacement of either the master or the slave cylinder - sorry I can't be any help, you will just have to front up with the cash to replace either part...
One way I can think of to help to narrow it down would be to clean both master cylinder attached to pedal and slave cylinder on gearbox, and dry carefully. Top up the reservoir. Press down the clutch pedal and jam it using a jack handle (or similar) pushed against the driver's seat, sliding the seat forward if necessary. Then leave it overnight, and check the cylinders thoroughly for leaks.
Of course after all this you probably don't have a hydraulic clutch anyway... so let us know how you get on, won't you? ;-)
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 22-11-2004   #3
Trader Rating: (0)
Re: Gears
Thanks a lot.
Yeah, i do have a hydrolic clutch.
I took it to the mech and he told me thats its probably the master cylender as there seems to be a leak near the clutch pedal.
Thanks for your help and I'll be sure to keep you posted.
The car goes in tomorrow evening and I should have it back wednesday evening or thursday morning.
Deitel is offline
Old 23-11-2004   #4
alexGS's Avatar
Trader Rating: (1)
Re: Gears
Deitel,
good that you've found the problem (well I think you've found it, anyway) and best of luck with the replacement. I've learned something too because I didn't know that the Uno 45 FIRE had a hydraulic clutch, I've only seen Mk1 models.
-Alex
alexGS is offline
Old 25-11-2004   #5
Trader Rating: (0)
Re: Gears
Got the car back today.
Problem all fixed and running smoothly.
Deitel is offline
(T) gears dificult to engage when cold teulk Punto 14 26-10-2004 15:53
(T) crunching and stiff gears klee63 Cinquecento / Seicento 4 08-10-2004 19:53
(T) Crunching gears rongo Punto 8 27-09-2004 17:19
(T) Thud when Changing gears or on pullaway yuthimon Bravo / Brava 1 17-03-2004 21:43
(T) Dodgy "Gears" 1995 1.1 SX Punto - what is it ? Steve_pye Punto 6 29-01-2004 09:37
