The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Old 30-06-2009   #1
a73uk has donated!
FIRE carb kits
I`m going to strip, clean & rebuild my carb (32 TLF 12 on the 1108cc FIRE) due to an intermittent idling issue (occasionally wont idle, I suspect due to dirt in the float chamber/jets).
The cheapest place I can find for the kit is Webcom @ £28.61.
I havent done carbs for a few years, but carb kits used to be under a tenner!
£29 seems a bit steep for what is essentially a few bits of card, a couple of 1" square bits of rubber with some plastic & a screw.
Anyone got them cheaper anywhere?
Currently got.. 89 Panda 750L, 90 Uno 60S, 93 Tempra 2.0ie SW, Jaguar XJR V8, a Porsche Boxster, 2x Daimler XJ40`s, 96 Punto 1.6 Sporting (breaking). The Uno is the most fun!
a73uk is offline
Old 30-06-2009   #2
re: FIRE carb kits
im going to rebuild my webber so i will also be interested in where's cheapest
randomspeedfreak is offline
Old 30-06-2009   #3
Scarlet
CLXCraig's Avatar
CLXCraig has donated!
re: FIRE carb kits
Carb kits may be an easy choice but another member once recommended using ultra sounds to get ridd off all the bits of crap in side a carb. Said it worked better than the kits.
bit hard to get hold of one unless you own a tattoo parlour
1993 Panda CLX
1993 Panda Fizz
CLXCraig is offline
Old 30-06-2009   #4
a73uk has donated!
re: FIRE carb kits
You still need a gasket kit to put it back together properly after youve cleaned it though Craig.
You can make them, but they are quite a fiddly shape on carbs.
As long as your careful, theres no harm in cleaning them manually, a can of aerosol carb cleaner & a toothbrush does wonders very quickly & its hardly a complex carb, so I think the ultrasonic things overkill!
a73uk is offline
Old 01-07-2009   #5
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Drives:
Ucof has donated!
re: FIRE carb kits
I used neat Reddex in my carb to clean it all out, worked perfectly
Ucof is offline
Old 02-07-2009   #6
a73uk has donated!
re: FIRE carb kits
Redex or carb cleaner down the choke will clean the inlet & choke area to a small degree, but if you`ve got sediment inside the float chamber or trapped behind a jet (which is what I suspects wrong with mine, you`ll have to strip the carb to get to it.
Sometimes the gaskets will stay intact when you open the carb up, but while you`ve got it open you might as well clean the lot properly, check for throttle spindle wear, change the diaphrams & stick it all back together with new gaskets after.
Then you`ve got a nice clean carb that shouldnt give you any agro for a while.
You should then change the fuel filter & ideally the engine bay fuel pipes, they are likely to be very brittle if they havent been done before, I`ve seen quite a few with the pump to carb pipe splitting & believe me, when they go, petrol goes everywhere....
Bacon fat can also be smeared over the carb to protect after it Ucof... but dont use it on any rubber parts.
a73uk is offline
Old 02-07-2009   #7
Powered by Bacon.
Ucof's Avatar
Trader Rating: 1
Drives:
Ucof has donated!
re: FIRE carb kits
This is good news.
I like bacon.
Ucof is offline
Old 05-07-2009   #8
Drives an Alfa Romeo :o
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
re: FIRE carb kits
Hmmm... I usually just re-use the gasket
I think you should replace the fuel inlet needle valve - may not be absolutely essential but it is a part that wears.
I often find it helpful to drill out the idle jet a small amount - from 0.43mm to 0.5mm - using a tiny drill. This helps the mixture screw to actually have some effect. I suspect that excess air gets in around the throttle spindle when the carb is old.
Check that the choke pull-down capsule is working - I have seen a couple that didn't.
The best thing I ever discovered for carburettors is compressed air... blow out all the residues from cleaning, and banish blocked jets for good.
-Alex
Things are much simpler now that I have only the '88 Uno Turbo i.e., the '03 Alfa Romeo 156 TSpark Selespeed, and two other 164s, an '89 and a '92... and a Suzuki scooter of course!
alexGS is online now
(G) Carb tuning 999 Fire saibeml Uno 2 19-03-2009 19:24
(T) carb repair kits shaun X1/9 9 10-12-2007 22:16
Carb fed fire AIJ29 Panda (Classic) 11 13-08-2005 21:36
(G) FIRE 999cc Carb or Injection SuperUno Uno 1 24-06-2005 17:18
(T) Carb reconditioning kits Luke Uno 10 12-05-2005 02:40
Copyright ©2002 - 2010 FIAT Forum
