The FIAT Forum
Old 06-11-2004   #1
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Smile Jet-up to fix FIRE idling
Yeah sorry but I think this is a big deal - I sorted the greatest pig-of-a-job I've had in ages. 1.0 FIRE (carb) engine, barely idling, more like bucking and kicking around the engine bay. You know the type - mixture adjustment screw seems to make no improvement, just even worse...
Swapped ignition parts etc. with no improvement.
On the good advice of a specialist, I jetted-up the carb. The idle jet is the one with the larger slot-head (tiny hole in middle). The jet itself pulls off the screwed-in holder. It was a '47', and I had a few other jets out of Uno and X1/9 double-barrel carbs. Basically I had a '50' and a '70'.
Being the sort of person that I am, I stuck in the '70' (even though that was designed for a larger engine and for high-speed progression onto the secondary barrel) and reassembled airbox etc.
Result - suddenly the mixture screw has an effect, suddenly the engine is smooth and starts nicely with the choke instead of firing and dying.
Theory - wear in throttle spindle allows more air into an already-lean setup (for reduced emissions). Larger idle jet = more fuel at low loads = theoretically higher fuel consumption but in practice, smoother running and easier takeoffs probably use less fuel.
Just a hint, though really I owe Maurice Thomson (Te Awamutu, NZ) a big thanks, and probably shouldn't divulge his secret (except that I knew this trick before from similar improvements on an Uno 70...)
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
(G) UNO 1.1 i.e. idling problem andre79ge Uno 5 11-10-2004 13:28
Fire/No Fire Nacho Panda (Classic) 7 17-07-2004 21:21
(T) uneven idling (again) and acceleration Achtung Bravo / Brava 6 28-02-2004 15:13
FIRE engines. sabeltandcavia Panda (Classic) 4 24-02-2004 15:06
(G) Fiat Uno Fire running rough mae Uno 3 28-11-2003 04:19
