The FIAT Forum
Old 03-11-2004   #1
Trader Rating: (0)
water pump
has anyone got ideas for fitting a water pump onto a 1100 uno selecta.i cant get to the 4th nut as fiat have stuck some sort of skirt next to the wheel making things difficult many thanks jim
auntiemary is offline
Old 04-11-2004   #2
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: water pump
I'm guessing a little but I think this is the 1116cc engine (not 1108cc?)
In which case (1116cc), why not take the pump body off the engine - in fact I'm pretty certain you have to do this anyway because pump impeller won't fit out between engine and engine bay side.
There are four bolts holding pump body on, plus two securing water pipe which you can reach with l-o-n-g socket extension working between exhaust and block. You will probably have to remove exhaust heat shield and alternator tensioner bracket in order to be able to remove pump body from block. Sorry, sounds difficult but I turned the job around in two hours.
Anyway those are just my ideas... ;-)
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
(T) Water Pump major leak red_cinqo Cinquecento / Seicento 2 25-10-2004 23:10
(T) instructions on how to get to mk2 punto water pump Lemzip Punto 8 23-09-2004 21:02
(T) Water Pump?? Azmondo Punto 3 15-05-2004 22:09
(T) fooked water pump? custard Cinquecento / Seicento 4 16-03-2004 07:38
Water pump go2helenback Panda (Classic) 7 16-02-2004 02:35
