The FIAT Forum
Old 17-10-2004   #1
Trader Rating: (7)
Suriname
Jumpy speedo needle
Ive got a jumpy speedo needle, anyone any ideas what could be wrong?
chrisunoman is offline
Old 17-10-2004   #2
SpongeBobSquareCar's Avatar
Trader Rating: (0)
Re: Jumpy speedo needle
Think the weights in the back of the unit may have become bugger'd (sorry for the technical lingo)
SpongeBobSquareCar is offline
Old 17-10-2004   #3
Trader Rating: (0)
either your speedo cable or the speedo cluster, as it happen to me!
MeAcHeM45 is offline
Old 18-10-2004   #4
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Speedo cable needs clean and re-grease - pop off the instrument cluster lid (back first then front), undo two screws holding in instrument cluster, pull speedo cable collar away from instrument, pull speedo cable off instrument.
Withdraw the speedo cable inner part, clean with WD40 and paper towels. Apply a smear of lithium grease, push back into the cable. Should be quite easy to engage in transmission - twist to make sure.
Refitting the cable to the instrument can be tricky - you have to make sure it's fully pressed-in before you slide the collar back into place.
If this doesn't fix it, check that the speedo cable in the engine bay follows a smooth curve to the transmission. Small kinks can often be straightened out.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
(T) Sei Sporting - Speedo probs, plus more!! Hallsy Cinquecento / Seicento 16 05-02-2006 17:10
(G) bouncing speedo needle trublue Uno 2 07-07-2004 09:25
(T) Speedo similarities... arseofbox Cinquecento / Seicento 8 02-06-2004 19:19
(T) Erratic speedo needle walsave Punto 2 15-10-2003 19:17
(T) speedo problems grahamedriver Punto 1 20-05-2003 04:09
