The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Old 21-02-2009   #16
Biz
The Big-Indecisive-Zebra!
Biz's Avatar
Trader Rating: 2
Biz has donated!
Re: fiat uno turbo ie 1988
Cool, good to see you have some knowledge to work from
Would you want to the Uno to do that rally?
The future is small and forced induction!
Target - Uno up to 180mph.
Biz is offline
Old 22-02-2009   #17
thank you ..i know the site good info there...read it at leas twice
Project UNO TURBO IE
unoturboCRC is offline
Old 22-02-2009   #18
if i can get the hand brake to work properly ..yes i will use it in the local championship. i dont need much power there..as the circuits are slow and with a lot of bends ( mostly "U" turns)..the uno is more than capable
Old 22-02-2009   #19
does anyone know what the standard fuel pressure regulator works at. i need to kow the standard pressure, soo i can adjust it
Old 03-03-2009   #20
nobody here knows the standard pressure for the fuel regulator..nobody has the manual for this car .....
Old 04-03-2009   #21
Australia
standard pressure is 3 bar at 1 atm.
SteveNZ is offline
Old 04-03-2009   #22
thnaks for the answer..but i think that's the fuel pump's pressure, i wanted the pressure of the fuel pump regulator..the one in the picture..
Old 10-03-2009   #23
Originally Posted by unoturboCRC View Post
Hello, i am new to the forum, and i'm a fiat owner since december last year. i've searched the forum a bit but could not find enough data for me to fully undestant the potential of this car. what i want to know is how to get more power from my car. how others did...
I have just rebuildt the engine as it was a wreck..334.000 km..you can imagine..i spent a lot of money on this..anyway..
i already have:
- boost controler
- blow off valve
- clean exhaust
- big intercooler (not fitted yet)
- plans for reducing weight
i read something about, an x1/9 1500 engine cam ...
and i also read something about water injection..but it is very dangerous if you do it wrong ..soo i am stil reading
please point me in the right way...
i attached some pictures of the rebuild procedure..
if you have a problem with my english ..is because i'm from Romania..
am a uno lover mate getting more power reflecks on how big ya wallet is mate,so let me know ya budget and i can give you some sound free advise mate
justaboy69 is offline
Old 12-03-2009   #24
Great job! Totally different subject, anyone know where I can get an engine mount for a mk1???
barnard00 is offline
Old 12-03-2009   #25
Jai
BLUES+TWOS! PANDA+UNO!
Jai's Avatar
Trader Rating: 6
Jai has donated!
inter parts hounslow, when i ordered them last year, had all three on the shelf within a day, £50 odd
<a rel=http://www.fiatforum.com/gallery/data/892/sig371.jpg" border="0" />
1988 MK1 FIAT Uno Turbo i.e. - the quick white one
1990 MK1 FIAT Uno Turbo i.e. - the quick red one
1996 Mitsubishi Pajero Junior ZR-2 - the reliable one
2004 FIAT Panda Eleganza - the wifes one
Jai is offline
Old 13-03-2009   #26
@justaboy69 i am way off-buget now...spent very much on rebuilding it than on tuning it....
but if you can help with ideas starting from cheap to expensive i would be gratefull to you.
Old 13-06-2009   #27
i read that this engine with it's own(stock) turbo makes full boost in 4th gear around 3500 rpm...knowing this i tested the stock car, and i confirmed it, and after that i installed a boost controler..i adjusted the bost gradually to about 1 bar i think question:
- when i press the acceleration to the floor in 4th gear around 3500 rmp the boost rises to a max of 1 bar ..but just for a second..then it drops to 0.7-0.8..and stays there. what i'm asking is: is this the "1 bar limit" or i can safely raise the boost until it stays at 1 bar in fool thotle in 4th gear over 3000 rpm ? ?!?!?!
Old 15-06-2009   #28
Drives:
gdrake88 has donated!
Originally Posted by oldskoolmk1unoturbo View Post
i've got a turbo dynamics hybrid turbo on my mk1 and it spools up quicker than the standard turbo and can produce more boost,
how much was it? oil seals have just gone in mine so im looking for a new one, what engine mods have you had done?
gdrake88 is offline
Old 16-06-2009   #29
cost new from turbo dynamics is about 750 quid, good for 200bhp,
other modifications i have are K&N air filter, Pace alloy intercooler, scorpion exhaust with powerflow backbox, FSE adjustable fuel pressure regulator.
oldskoolmk1unoturbo is offline
Old 17-06-2009   #30
Drives an Alfa Romeo :o
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
That's not the "1 bar limit" - the reason you shouldn't go over 1 bar is because that is all the injection ECU 'knows' how to add fuel for. More than 1 bar and you risk underfuelling - lean running, melting pistons, etc.
There is a switch on the end of the plenum chamber that cuts out the ignition at 0.6-0.7 bar - so that is the standard 0.7 bar limit. I expect you have already disconnected that switch.
If you can't sustain over 0.6 bar it sounds to me like you have a boost leak. A split in a pipe opens when you hit 1 bar, and then some of the pressure leaks away. Go right through the pipework inspecting for slits (also listen for odd noises under boost), start at the pipe from the turbo itself, and don't forget to check the plastic end tanks of the intercooler.
Also bear in mind that under hot conditions with the standard turbo, you may find the boost level drops off slightly (e.g. to 0.9bar) at high RPM (say, over 6000) due to clever engineering of the turbocharger being ideally suited to the engine. A larger turbo will carry on boosting (and over-boosting) at high revs. The power peak of the Uno Turbo engine is quoted at 5600 (from memory).
-Alex
Things are much simpler now that I have only the '88 Uno Turbo i.e., the '03 Alfa Romeo 156 TSpark Selespeed, and two other 164s, an '89 and a '92... and a Suzuki scooter of course!
alexGS is offline
1988 Uno Turbo Chas Uno Auction Watch 11 05-06-2008 20:39
(G) 1988 Uno Turbo Waderider Uno 27 22-10-2006 23:47
Copyright ©2002 - 2010 FIAT Forum
