| hi fellow uno chums i have a problem i hav fiat uno 1.0ie mambo and hav 13inch MKII turbo alloys go on fine but cant get full lock and rub when turn so brought spacers mission 2 get on i hear they improve handling but wear the bearings down quick i no i need tracking done cause shakes when get 2 60mph. so i got 2 run it through a garage but im wondering if the garage will fit my bolt-on filter and my universal exaust due 2 it is a 1.0 ie not goin ne quicker but dont want 2 lose performance any body know a price of how much it will cost for garage = put on alloys, spacers and trackin fit bolt-on and put on uni exhaust appricate if sum 1 could give me a estimate
| Re: Alloys Bolt-On And Uni exhaust Shaking at high speed will be due to the wheels needing balanced. Only if the car pulls to the left or right, or has unusual tyre wear - that's when you get the tracking looked at.
__________________ Regards, Martin | |||
| | #3 | ||
| NobodyBlamesTheHappyGuy:D | Re: Alloys Bolt-On And Uni exhaust OK. Please write so it is possible to read. Full sentences. Correct language. It is very difficult to read especially when english is my 2nd language. As Martiny says, you propably don´t need tracking. Get a garage to balance your tires. If you can change a wheel on and off, then you can mount the spacers as well. Are you sure of the offset? I´ve got 14" alloy wheels from the Strada Abarth, which requires 20-25 mm spacers. I got them from Momo which is held to the hub by replacing one of the two bolts in the hub for positioning steel wheels. Spacers will not wear out bearings, it is just an extension of the wheel. The bolt on filter is also easily replaced. One bolt on top of the filter housing, and a clip at the engine alloy head. Remove and unclip the hoses. Remove the filter housing adapter, and fit your new filter... Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. Last edited by Morty Mort; 07-10-2004 at 14:10. | ||
| | #4 | ||
| :) | Re: Alloys Bolt-On And Uni exhaust morty, it's hard enough to read that with my level of English to be honest!
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #5 | |||
![]() Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | |||
| | #6 | ||
| Re: Alloys Bolt-On And Uni exhaust thnx mort nice bit of info there waht about the uni exhaust any ideas i no ` the siz of the uni 3inch
| | #7 | |||
| Funny saying here | Re: Alloys Bolt-On And Uni exhaust Read above posts and the one called "language" might help you even more! http://www.fiatforum.com/site-ideas/17942-language.html
| | #8 | |||
| Back once again w'the... | Re: Alloys Bolt-On And Uni exhaust I'll back you up too, Morty :-) I had to re-learn how to write properly, as a result of my job. I had to write articles for a monthly magazine, which really helped me to write more clearly. English was always my best subject at school, but many people seem to find it easier to write in that strange way, with shortened words and no punctuation. I find it really hard to write like that, though obviously it would be cool if I could! Now I notice that it's the people with English as a second language that seem to write best, on-line. A little hint for anyone reading this far... Try to have only one main subject per paragraph, and never switch subjects mid-sentence: it's just too confusing. Never have more than five lines per paragraph. That follows on from keeping each subject in a separate paragraph. Since I was writing for the IT industry (Visual Basic programming) I also noticed another disturbing trend. People without much knowledge in the field tend to use jargon a lot, probably to sound more impressive. It's unnecessary. Most of the time you can explain things without jargon. This rant from me was not aimed at Trowa20uk in particular - it just seemed like a good time to put my thoughts into words! Now, onto the problem... Trowa20uk - what size are the tyres? The wheels themselves shouldn't cause a rub because the offset is correct, but standard tyres for an Uno Turbo are only 175/65/13. I have 185/60s on mine, and the left one rubs the gearbox slightly. It's actually not a big concern if you take care during U-turns and parking manoevures. Some Unos and older FIATs have a 'spacer' as standard - it's just a metal disc about 5mm thick, fitted onto the brake disc before the wheel goes on. If your Uno doesn't have them and you're keen to save money, ask at a few scrapyards. Should be worth only a couple of quid. I agree with Martiny - the shakes is a wheel balancing issue, the alignment is probably fine, but check the tyres that have been fitted to the car (or get a second opinion if you're unsure). If the alignment is out, it shows in the wear pattern on the tyres. If the tyres are worn heavily on one edge (inside or outside) it shows that the toe setting is out. Only the toe setting is adjustable at the front of Unos, and the back suspension isn't adjustable at all, so a wheel alignment just means an adjustment of the front toe setting (which, now I think about it, is why you called it 'tracking'! :-) Beware the garages that charge for a '4-wheel alignment', even when they can't do this to an Uno. About the filter and exhaust... getting a garage to fit the exhaust I can understand, but I really think you should look at the filter yourself and work out how to fit it. Is it the right type for the 1.0 engine? Because I live in New Zealand I can't comment on the labour rates you would pay at garages, but I think one thing is for certain: the more work you can do yourself, the better off you (and your Uno) will be in the long term. -Alex
| | #9 | ||
| Re: Alloys Bolt-On And Uni exhaust The fact that the turbo alloys rub makes me think that they might be cinquecento sporting alloys instead as these look the same but (i think) have a different offset.
| | #10 | ||
| NobodyBlamesTheHappyGuy:D | Re: Alloys Bolt-On And Uni exhaust Are you guys sure about the offset not differing between the Uno Turbo and Uno 1.1 etc. I think the turbo has double (ventilated discs) demanding a bigger alloy offset than the standard. I'm not sure though. There is a big difference between the wheel offset for the Strada 85S and the Strada 130TC due to brake differences. Morten.
| | #11 | |||
| Back once again w'the... | Re: Alloys Bolt-On And Uni exhaust Good point Monty, but I've seen Uno Turbo alloys fitted to an Uno 60, an Uno 70, and an Uno 45, all with no problems. -Alex
| | #12 | ||
| Classic Uno Obsessive | Re: Alloys Bolt-On And Uni exhaust RE: Writing understandable English Well said Morty Mort and those people who stood up for writing English properly on the boards. This is a great forum, but many times I've struggled to read an article because the writer uses mobile phone 'text speak' rather than understandable English. I brought this up on the board a few months back, and whereas 'text speak' is ok for mobile phones (where the number of characters one can use are limited per message) it is pointless on a discussion board. It's one thing trying to send a simple message to a friend via phone, and something totally different when talking technical terms on a board like this. At the end of the day, it just makes the writer look both lazy and illiterate. It is also rather inconsiderate to our international Uno friends who understand English as a second language and who probably never use 'text speak'. So guys and girls, can we keep text speak for mobile phones only and proper English for the discussion boards? It would just make it easier for everyone in the long run. Chas
| | #13 | ||
| Tires the problem?
