The FIAT Forum
Old 23-09-2004   #1
Trader Rating: (0)
Replacing Vaccum advance (Uno 1100 ie FIRE)
I seem to have a problem which has been adressed many times on this board:
When hot the engine idles poorly and often cuts out at low revs (Uno FIRE 1.1 ie Injection model with ECU).
Having read many of the previous threads I plan to replace the vacuum advance unit on the distributor. I am living in Italy so should have no problems in obtaining the part , BUT am not sure how easy the replacement is.
I am relatively handy, but have little experience of auto repair and no specialist tools, can anyone advise me on whether I should attempt this myself or visit my local Fiat mechanic
many thanks,
Iain
Iain is offline
Old 23-09-2004   #2
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: Replacing Vaccum advance (Uno 1100 ie FIRE)
Hei.
You can do it yourself. It is two screws on the distributor. Remove the distributor first, after unplugging th HT leads. Use a permanent marker or scratch it's position to the engine head. Then you won't disturb the ignition timing when you replace it. It may be a little fiddly to remove the vacuum unit itself, but if you remove the cap and rotor, and the shield within, you will be able to see inside the distributor.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 01-10-2004   #3
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Morty Mort - does the dizzy (sorry, distributor ;-) really have to come off?
I'm pretty sure I've replaced the vacuum advance with the distributor still in place.
Iain - The operating arm (yellow plastic inside the distributor) from the diaphragm has a slot in it - use a screwdriver in the slot to loosen the grip on the pickup plate.
Don't forget to check the vacuum pipe all the way to the carburettor - it's easy for this to crack near the carb.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 01-10-2004   #4
Morty Mort's Avatar
Trader Rating: (1)
-Alex
No.
But if you get really angry when working on it when it´s dark outside - then remove it and take it inside, instead of having a nervous breakdown.
Morten.
(G) uno fire 1100 running very rough stash Uno 3 08-06-2004 11:57
(G) UNO (999cc FIRE) vacuum advance question Sreenath B.H Uno 2 15-05-2004 21:01
(G) uno fire 1100 gearbox refill stash Uno 2 18-03-2004 14:51
(G) uno fire 1100 head bolts torque settings stash Uno 1 08-02-2004 21:46
(G) fiat uno fire 1100 petrol pump stash Uno 0 08-02-2004 14:55
