The FIAT Forum
Old 21-09-2004   #1
Trader Rating: (0)
Clonking
I have a MK1 Uno 45, 1 Litre. I am getting an intermittent clonking noise form the front left hand side of ther car, mostly when coasting on slowing down but occasionally it comes anytime.
Having said that this morning I drove it and there was no clonk at all except for on the retun journey.
It has new CV and tripode joints and boots etc so it aint them......everything else looks and feels as tight as it should be, no obvious leaks on the shocks etc and it is really peeing me off not being able to put me finger on what it is.
Any ideas??
Cheers.....
ps thought I had cured it last night by using a longer handle and getting an extra half turn on all the nuts n bolts but obviously not!!!
dansdad is offline
Old 21-09-2004   #2
Moderator
Trader Rating: (7)
Steven has donated!
Re: Clonking
It sounds like a CV joint. When were they changed?
Steven is offline
Old 21-09-2004   #3
Trader Rating: (0)
Re: Clonking
I personally changed them on Saturday cos thats what I thought the problem was too!!!
dansdad is offline
Old 22-09-2004   #4
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Clonking
dansdad - Control arm balljoint perhaps? Common failure, hard to test while mounted on car. You have to pry against it with the car jacked up. Any strange feelings in the steering/lurches?
If no strange feelings then noises may be from the strut/strut top mount, perhaps get one from a breaker's to try a swap. There really isn't that else to make a knocking noise - the gearbox mount loose maybe?
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 22-09-2004   #5
Trader Rating: (0)
Re: Clonking
Steering feels fine and balljoints tight etc
Clonk seems to be happening when I come off the gas and coast.....then stops when I brake or let the clutch back in.
Gearbox mounts seem ok although engine mounts look a bit wooly but as I dont know how "rigid" they supposed to be in the first place I dunno whether its them or not??
At this rate I will end up changing everything!!
dansdad is offline
Old 23-09-2004   #6
Trader Rating: (0)
Re: Clonking
There`s more!!!
Drove car this morning and it clonked all the time, had a 15 stone mate sit in front with me and NO clonks!!
Made him move to back seat, clonking returned with a vengeance and wouldnt stop even after he got back in the front.
Could it be a shock on its way out??
dansdad is offline
Old 23-09-2004   #7
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: Clonking
Or could it be the exhaust? Check all flanges and mountings from manifold to rear silencer.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 01-10-2004   #8
alexGS's Avatar
Trader Rating: (1)
Re: Clonking
Yeah, sounds like the exhaust now you describe it changing with weight in the car! Quite a common problem with the exhaust clonking on the rear beam with Unos...
The engine mounts, y'know, I've looked at those MANY times and thought they were too soft! They are very soft in an Uno to improve the refinement c.w. the earlier 128s etc. I doubt that they are your problem!
BTW check your handbrake cable on the rear beam - not because it will be causing the clonking, but because the exhaust usually makes a mincemeat of that cable!
-Alex
alexGS is offline
Old 16-10-2004   #9
Trader Rating: (0)
Re: Clonking
I was getting this noise too. One of my brakes was binding .. Just cleaned the area where it holds the pad (was rusty) and its fine now ..
To find out if it is indeed your brakes, apply little brake power. Noise should stop. If you can still hear it while braking then its something else..
Mazz0 is offline
(T) Clonking brakes!!!! gooseboy77 Punto 2 13-06-2004 19:54
(T) Clonking noise when turning right keef444 Bravo / Brava 2 24-03-2004 02:51
(T) Clonking noise Silver_Sei Cinquecento / Seicento 3 28-10-2003 01:04
