Thanks for the advice, u seem to have your head screwed on!!
If as you say the delta 1.6 8v turbo lump will go then will the dedra 2.0 8v turbo or the croma 2.0 8v turbo as i have seen hf owners dropping these straight in the deltas? They seem to hike up the torque figures and be more tunable???
Just because the 1.6 Delta 8v will fit does not mean the 2.0 engines will too. I assumed that the 1.6 Delta HF engine is from the same family as the 1.1/ 1.3/ 1.4/ 1.5 series of ohc engines (as fitted to the Uno 1.1, 1.3 (+ turbo), 1.4 (+ turbo). That's why it will swap in place of the earlier non FIRE ohc Uno engines, and bolt up to the standard gearbox, if that is the case. However, I am NOT sure on the origins of 1.6 Delta engine but I am fairly certain it is NOT from the same family as the bigger twin cam 2.0 litre engines. Therefore you will not just be able to drop a 2.0 8v turbo engine in place of a 1.3/ 1.4 turbo.
Added to this is that you have a 45S Uno that uses the 999cc FIRE engine. The engine and running gear are totally different to those fitted to the turbo models, so you'd have to upgrade to UT running gear before you can even think of swapping in a bigger engine. There's no way a 999cc FIRE gearbox and driveshafts will cope with much more than 100bhp!
Also, the reason that the bigger 2.0 litre 8v lumps will swap into the Delta HF is because the Delta was designed to take bigger engines in the first place. The Delta is a bigger car with a larger engine bay and also has the availability of running gear designed to cope with both the power and torque of the bigger engines. The biggest engine fitted to the Uno is the 1.5 sohc lump - the larger twin cam Fiat/ Lancia engines were never fitted as standard.
This is what I mean about it being a lot of work. You'll be looking at fabricating engine/ gearbox mounts, custom made driveshafts, modified hubs, brakes, exhaust system, cooling system, wiring harness, ecu etc. etc.
You'll also need to look at how much extra the new engine and gearbox will weigh compared with a standard Uno drivetrain. If you're lucky and it's all alloy it might be a similiar weight and you won't upset the handling too much. If it all adds up (bigger gearbox, driveshaft, hubs etc.) you'll be adding extra weight to the front and mess up the handling in the process.
Dont get me wrong i love uno turbos but this time just want to do something a little different and more challenging than a simple swap over!!
This sounds like it may be a major project rather than just "more challenging"! You're also not the first to ask about fitting a 2.0 litre turbo engine on this forum, but as yet no-one has actually built one after asking. That probably speaks volumes as to the complexity involved. The only 2.0 Uno I've seen was a south African monster that used a Japanese 2.0 litre turbo engine. It required MAJOR surgery and restructuring along with serious money spent on it.
I'd love you to prove me wrong and find an easy (ish) big engine swap into a Uno but as of now there isn't one widely known. If there was, then I can guarantee more of us would already be running bigger engines
Perhaps your best bet is to ask on Turbocollective about it as they may have more information on such a conversion?
