The FIAT Forum
Old 09-09-2004   #1
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Exclamation Hot air intake to air filter
Just a thought with summer on the way (sorry, winter for most of you lot!)
Check the air filter housing flap (1116cc/1301cc models) that selects hot air from around the exhaust manifold or cold air from the front. The flap is supposed to start off with the cold air sealed off. A wax capsule expands and pushes the flap open when the temperature increases.
My tests show that the wax capsules (tested two of 'em) simply don't work when needed. Flap stays in the hot-air position even when engine bay baking hot. Testing with hot-air gun showed that capsule started to open more or less as the plastic of the air filter housing melted.
My suggestion - until we come up with a better solution, pop the casing apart and remove the flap. Block off the hot air intake. Unless you live in the northern hemisphere - in which case, now would be a good time to check your hot air pipe (to manifold) is in place.
I'm thinking of a microcontroller-controlled motor to close and open the flap when needed (properly).
Cheers,
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 09-09-2004   #2
Trader Rating: (0)
Re: Hot air intake to air filter
Another slightly easier but more compromising solution would be to remove the flap, but instead of completely blocking off the hot air intake, use a partial block ie leave a smal cut out approx 1/4-1/3 the size of the entire opening. This will allow for when the weather is cold but wont pump through so much hot air that it has a hugely negative effect on the performance. In fact the engine could do with a small volume of warm/hot air at all times for it to work best, just not as much as a completely unrestricted pipe would let through.
Leon.
Leon1.1 is offline
Old 09-09-2004   #3
Trader Rating: (1)
ts86 has donated! United Kingdom
Does this feature on the 1108cc engine?
145 QV
156 2.4 JTD
ts86 is offline
Old 09-09-2004   #4
Trader Rating: (0)
Yep It does indeed....It is a feature found on most cars....and removing it completely isn't the best answer for most SPI or carbed engines especially in winter, as they do rely on some warm air to run best even when the weather is hot. If the weather is hot you can get away with removing the pipe and the warm air is provided by the engine heating up the engine bay....but the best bet is to leave the pipe connected ... but control the flow rate/ volume of warm air.....of course where people go wrong is by overdoing the shift in ratios warm to cold.....by design the cold air is somewhat force inducted into the airbox by the forward speed of the car, which also has the effect of cooling the air down through wind chill.....the warm air simply is sucked up by the vacuum produced from carb/SPI and a little by the cold airflow dragging across the opening to the warm air duct hence you will never get greater volume of warm air than cold as long as you draw the cold air from the front of engine bay(ie right behind grill area). The best thing to do is to ensure a fairly large 'scoop' to collect the cold air....followed by some heat shielded piping to the airbox, and if possible heat shield the airbox itself too. Then restrict but maintain a constant warm air supply via the original pipe from the manifold.
Easiest way to set it up is get the cold air going in how you're happy. Then make some restrictors for the warm air with different diameter holes getting progressively larger. And basically test your car running with the different diameters until you find the one that allows the engine to run the best. Then stick with that one and enjoy.
Leon1.1 is offline
Old 10-09-2004   #5
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
I have to say. Throw the whole air-box. Insert a conefilter from K&N straight onto the SPi. Route a 50 mm flexible hose from front and appx. 50 mm away from the filter. During winter, just route the hose somewhere else. I´ve done this to my 1993 Uno 1.1 i.e.S.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 10-09-2004   #6
alexGS's Avatar
Trader Rating: (1)
Fair enough, Mort! I'd have thought you had problems in cold weather but then again you don't have one of those poxy 2-barrel carbs. :-) I know, I know, they ought to be great but I find that Unos are very patchy to drive, plus of course the starting difficulties as mentioned in the other thread.
I guess what I was fishing for with this thread was - does anyone's thermostatic flap seem to operate correctly? Has anyone replaced the wax-capsule thingie?
-Alex
alexGS is offline
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(T) hot air intake imola_fowkes Cinquecento / Seicento 2 04-09-2004 16:47
(T) air box mod revisited jbackg Marea 1 18-08-2004 01:33
(G) 1.0 i.e. start (AIR FILTER?????) NIODE Uno 10 29-07-2004 07:21
Air Filter tipo_lincs Lets Talk FIAT 2 13-06-2004 21:07
