The FIAT Forum
Old 29-08-2004   #1
moshpit666's Avatar
Trader Rating: (0)
bolt on carb
i have had my uno looked at because of a lack of power+power distribution problem been told its most likely the carb and so if i have 2 get anew one shall i just get a K&N bolt on carb?
moshpit666 is offline
Old 29-08-2004   #2
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
Could you be more specific, like simptoms!!And try giving the carb a good clean
smokeme is offline
Old 29-08-2004   #3
Trader Rating: (1)
ts86 has donated! United Kingdom
Re: bolt on carb
Check the inlet manifold for leaks as well.
145 QV
156 2.4 JTD
ts86 is offline
Old 29-08-2004   #4
moshpit666's Avatar
Trader Rating: (0)
Re: bolt on carb
the car starts up and sounds bad, mainly due to a loose bearing on the cambelt, but when driving the car seems to lack power, (i.e. in second i will put the pedal 2 the floor and the car pulls away but in fits and starts, kinda doesnt get all the power down at once just decides when it wants to go and is as if i am coming on and off the clutch all the time, so my head bobs around in the car!
Old 30-08-2004   #5
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
What engine have you got? I would still say clean the carb, it´s worth it.
smokeme is offline
Old 30-08-2004   #6
Trader Rating: (1)
Re: bolt on carb
Smokeme, how would one go about doing this?
So far I'm thinking...
Take off air box and spray carb cleaner/spray in while revving the engine?
145 QV
156 2.4 JTD
ts86 is offline
Old 30-08-2004   #7
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
Or you could tear the carb apart, loose a few pieces put it back together and find car won´t even start . Use the spray then say how it went.
smokeme is offline
Old 30-08-2004   #8
minislapper's Avatar
Trader Rating: (0)
minislapper has donated!
Re: bolt on carb
Has it got manual choke? If so, when it's driving badly, does it run any
better if you put the choke on slightly?
Have you run the petrol tank low recently?
Carla, Minty & Harvey!!
minislapper is offline
Old 30-08-2004   #9
moshpit666's Avatar
Trader Rating: (0)
Re: bolt on carb
car is a 94 L reg 999 fire uno, generally the car is running on low fuel averaging a quater of a tank bc in a student and cant afford to fill up! my uncle is a mechanic so hes guna have a look. thanx 4 all ur help and i will post up when iv had it checked out and fixed!
Old 30-08-2004   #10
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
Finally someone thinks about posting the solution to their problem!!
smokeme is offline
Old 30-08-2004   #11
Trader Rating: (0)
Re: bolt on carb
Hope it's an easy fix !
Old 30-08-2004   #12
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
BTW if you constantly move the accelarator does it pick up(accelarate) faster?
smokeme is offline
Old 30-08-2004   #13
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: bolt on carb
If it's from 1994, it's most likely an injection unit and not a carburettor. Is the car named 1.0 ie or something. Then it's got a Bosch MonoJettronic (SPi) module. It's a hybrid injection / carburettor. Check this first.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 30-08-2004   #14
moshpit666's Avatar
Trader Rating: (0)
Re: bolt on carb
there is a lack of power when accelerating not an increase,if pumped maybe a better acceleration i will check. will check the spi thing when goes in 4 check up. i posted on here to see if i cud get sum help before i took it in,surely thats what this forum is for? sorry if i have wasted anyones time (smoke me)by posting on here !!!!!
Old 31-08-2004   #15
smokeme's Avatar
Trader Rating: (0)
Portugal
Re: bolt on carb
I´m just glad to be able to help, what year is the car and engine size or model if you don´t know.
smokeme is offline
Choke, carb, ignition??? panichat X1/9 6 10-09-2004 12:15
weber carb info panda racer Panda (Classic) 1 02-07-2004 02:15
(T) Front strut bolt (30mm lowered pics too) Bushboy Cinquecento / Seicento 25 17-03-2004 08:18
(T) carb and water mrf94 Cinquecento / Seicento 5 11-08-2002 19:57
