| We are now a two Fiat Family. I drove up to New Plymouth (about 3 hours drive from Wellington) last weekend to collect my new purchase. It is a 1986 MK1 Uno Turbo. It is completely original except for the unfortunate two-tone paint, which will soon be rectified. It has done 123,000 kms and is rust free except for a spot in the driver's door, which will be removed when the repaint is done. The drive back was great! I was amazed at the acceleration. ![]() Refueling in Waverly. $60 for the Fiat and $160 for the BMW (Gulp). ![]() Back at home. Don't worry it's not going to be living outside, there is a spot in the garage waiting for it. It also came with a carload worth of spare parts. Including gearbox, 3 sets of suspension and lots of odds and sods. I'll take some more photos once it stops raining.
| | #2 | |||
| Back once again w'the... | Re: These Uno Things are Addictive Haha! Hope you'd finished your 70SL project - 'cause now you've got the Turbo, you'll never go back ![]() The performance of the Turbo is just something else, isn't it? I had the same feeling the night I drove mine home six years ago. Driving gently on long trips, mine always gets stunning economy - well, maybe not stunning compared to a Prius, but 50mpg - 5.3L/100km, I was amazed. Much better than the 70SL can manage. It's the fuel injection that makes the difference. Is that an early Turbo with the Strada-type gearbox, or the later Tipo-type gearbox with the rods inside the car obscured by a black plastic console on the centre tunnel under the dash? i.e. can you see red carpet all the way across the car in front of the gearlever... Lots of the Turbos in NZ are the later type but judging from the 'N-reg' (as the English would say) I think yours might be an early one - particularly as you said '1986', d'uh! sorry The early gearboxes are not so wonderful - usually bad synchro on third and a bendy, wobbly gearshift - I expect you can improve it with some bushes to the linkage, and I find that Castrol VMX (from Repco) is the best oil for ageing gearboxes. The later gearboxes have an 80EP oil specified so you can use any 'normal' gear oil, but with the older ones it's essential not to use EP. VMX is the best non-EP oil I've found taking into account the modest price. Genuine FIAT oil (ZC90) isn't far behind, but a bit more expensive. Is there a sunroof? Couldn't see in the picture. Sunroofs are rust-central on an Uno... The Turbo, as an old car, manages to combine surprising reliability with a good dose of the performance it always had. There is likely to be rust in all sorts of odd places, so best of luck with your renovation! (Check the rear turrets inside the boot under the carpet). WOFs may require any number of repairs to brakes, suspension, and steering - all of which are worked quite hard since it's the heaviest Uno in the range. Things like the front anti-roll bar bushes can still be ordered new from Italian Autos in Auckland. I'd be interested to know how much you paid for this beauty - send me a private message if you like ![]() Oh, and Well done! ![]() Cheers, -Alex
| | #3 | ||
| Re: These Uno Things are Addictive The 70SL project is still underway, but I suspect that it'll be used more for transporting the dog around now. I was amazed at the speed and handling of the UT, in fact it left the BMW for dead on the twisty bits. I think it is an early one as there is red carpet as far as the eye can see inside. The gearbox is a bit sloppy and it did graunch a bit going into third, but nothing to scary. It came with a spare 5 speed out of a Tipo so I'll swap it over if the graunching gets worse or when I have some spare time. There is no sunroof, which I was very pleased about as I have no desire to give rust any more encouragement than it already has. It has been owned by a Fiat club member for the last 8 years or so, so has lead a fairly pampered life. I paid $1000 for it and a whole bunch of spare parts. Almost enough to build another UT..... The turrets and everything seem pretty rust free. There was some light surface rust, but that came off with a bit of a scrub. The only "major" expense I will have, apart from the respray, will be a set of decent tyres as the ones on it at the moment are some odd budget brand.
| | #4 | ||
| Re: These Uno Things are Addictive In NZ the correct size tyre for the Uno Turbo are rather hard to find. The tyre should be a 175 60 13 (people will look at you funny and say "Don’t you mean 175 70 13?"). I have found that the correct size tyre is essential. You can get away with running 185 60 13s so that might be a good bet. The joys of owning a 'weird' Euro car... The correct size for your 70sl will be 155 70 13. Once again an irritating size as all the tyre shops have heaps of 155 80 13s Sometimes I wonder if I would like an Uno Turbo, but I get similar performance out of my 1600 so I'll stick with that Good luck with your Uno, and if you feel like throwing it around a track, and dont mind the trip to Taupo it would be great to see it, as we go there reasonably frequently during the winter.
__________________ Current: 1987 Uno (1580cc), 1996 Bravo SX, 1990 mk1 Uno 45, 1980 Mini 1000 and a 1973 Mini 850 Old: 1994 Punto 90ELX, 1984 Uno 70S, 1989 Uno 70SL, 1988 Uno 70SL, 1986 Uno 45 FIRE, 1987 Uno 45 FIRE, 1987 Uno 45 FIRE, 1989 Uno 45 FIRE, 1989 Suzuki FA50 | |||
| | #5 | ||
| Re: These Uno Things are Addictive Yup 175/60 13's are quite hard to get hold of. I'd get 185/55 13 to keep the rolling radius as close as possible to standard. Matt
| | #6 | ||
| All Hail the Woodsman | Re: These Uno Things are Addictive Dunno about NZ, but yes the standard size is not that common and is normally special order and a higher price but they're certainly aren't difficult to get hold of, you just might not be able to drive in an expect them to have them in stock.
__________________ Alfa Romeo 156 GTA / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #7 | ||
| Re: These Uno Things are Addictive Thanks guys, I didn't realise that the tyres would be such a rare size. But then I am rapidly learning that nothing is typical when it comes to italian cars ![]()
| | #8 | |||
| Cinq gone, Uno asylum! | Re: These Uno Things are Addictive Congratulations on your Uno Turbo purchase! And I swear you Kiwis are taking over the Uno section of the forum ![]() Be great to see more of the UT, and hopefully you'll keep progressing with the 70S project too. I for one would love to see how it turns out ![]()
__________________ ![]()
| | #9 | ||
| Re: These Uno Things are Addictive I'm guess that the New Zealand climate is a little kinder on the Unos. That and the lack of salt on our roads no doubt helps ensure that there are plenty roaming our highways and byways. I finally got around to taking some more photos..... ![]() Abarth Magic: "0-100km/h 8.3 sec, Standing Kilometer 29.8 sec, Cruising Max 200km/h" ![]() ![]() Marvel at the two-tone paint effect, complete with masked off Turbo Decal ![]() ![]() The front seat is a little worn, but then it still supports my buttocks so I have no reason to complain. ![]() Complete with original AWA Clarion AM/FM stereo tape player. ![]() So many dials for such a little car ![]() ![]() Ooooh a 105hp turbo fuel injected clock, just what every car needs! ![]() ![]() It came complete with Motorsport New Zealand Homologation Papers so it is registered to go racing.
| | #10 | ||
| Re: These Uno Things are Addictive I think that bottom spoiler needs to go... Its not original and it kinda looks like a shelf. If you are a member of a car club you should get your clubsport licence and come racing with us I'm sure theres a FIAT club down your way.I'm just curious why your logbook says 2.2ltr engine... Is that the equivalent non-turbo size?
| | #11 | ||
| | #12 | ||
| Re: These Uno Things are Addictive If you're getting rid of the spoiler can I have it please? Matt
| | #13 | ||
| Re: These Uno Things are Addictive Taupo Car Club do winter dual sprints last Saturday of the month during winter. Next one is the 26th of July, then 30th August (I wont be there because I'm helping with Rally NZ), and the last one is 20th Sept (Not last sat this time). Go to their website if you are interested. You dont have to be a memmber of Taupo car club to compete (just a member of a MSNZ affiliated car club). We just use track two (the new part). Also the FIAT Club Waikato are headed that way on the 14th of September (this event is likely to be booked out as its part of a clubsport series that also involves Hamilton Car Club and Minis Waikato). Do you know why someone has painted the bottom of your car that colour? Is it proper car paint?
| | #14 | ||||||||
![]() Sure, come pick it up and it is yours! I know where there is another one if you want two.
| | #15 | ||||||
![]() My Uno Turbo's colour-matched to a refrigerator - just kidding ![]() Seriously, I knew someone who painted their Triumph Vitesse in Cadbury Purple, so I guess it's OK to pick a colour you are attached to. And I guess nothing would be more of an attachment than a cigarette packet ![]() -Alex
| What Do All These Things Do? | John R Smith | 500 | 32 | 13-02-2008 15:38 |
| Wee Addictive Web Game | Liam | Leisure Lounge | 26 | 26-04-2007 13:42 |
| V addictive IQ escape game! | J333EVO | Leisure Lounge | 13 | 04-05-2005 13:22 |
| Few Things I Need.. Anyone? | Adamski | Cinquecento / Seicento | 7 | 27-04-2005 10:21 |
| few things! | wkd cinq | Cinquecento / Seicento | 3 | 19-04-2005 17:22 |
