| Preheat System Hi I have a Uno 60D 1994 The preheater light is not coming on so it is hard starting the engine It starts ok when warmed up How do I carry out testing the system
| | #2 | |||
| Cinq gone, Uno asylum! | Re: Preheat System No idea, but it sounds like the glow plugs are worn. About all you can do as far as I know is substitute them with new ones. Good luck! ![]()
__________________ ![]()
| | #3 | ||
| Re: Preheat System When you turn the igntion on, there should be over 12v going to the glow plugs, put the red lead of a voltage meter to the nut on the end of the glow plug and the black to the body of the car or the negative of the battery, you should have voltage for around 12 seconds and about 20 seconds after the engine is started. If its a mk2, try looking behind the speaker grill in the drivers footwell, get your head under the dash and there should be a controller box for the glow plugs timer box, ive knocked the plug off the bottom before and had troubles starting!!
| 2.8jtd preheat | Torq | Ducato | 4 | 02-02-2008 15:45 |
| Preheat Fault on JTD Multiwagon | NobleSX | Stilo > Technical | 1 | 20-12-2007 10:14 |
| EOBD System Engine Control System | MatthewBlackburn | Punto > Technical | 2 | 12-12-2007 16:51 |
| Preheat Fault Warning | Jiminspain | Stilo > Technical | 5 | 15-03-2007 17:45 |
| For Sale: FK Automotive 30mm System B & System B spacers (Wheels) | J333EVO | For Sale / Wanted | 0 | 27-02-2007 12:14 |
