- Sep 2, 2007
- 126
- 112
Hi to all,
I have a problem which has emerged after new front wishbone arms were fitted on my car, which is an Uno 60 1992 with 1108cc engine.
New wishbone arms (supplied by me) were fitted to each side. No issues or concerns were mentioned by the garage when I collected the car.
Due to a different unrelated fault, the car was examined on a ramp at a second garage the next day and I witnessed the issue which they identified.
On full lock the n/s arm was in direct contact with the tyre and could cause major damage-a definite MOT failure item. For the o/s, however, there was plenty of clearance on full lock (probably an excessive amount).
I have double checked the wishbone arms are the correct parts and confirmed this fact. Also had tracking checked and adjusted and although the track rod end thread is not equal on both sides the garage is now saying that the steering rack itself may need to be centralised accurately-not a quick job by any means-to correct the fault with the arm rubbing the tyre on full lock (the car has never failed an MOT for this reason before).
The steering wheel position after the wheel alignment is about 'twenty to three' rather than dead straight (ie similar to before the arms were fitted), but the notches on the wheel spline are very widely spaced so unable to alter satisfactorily.
I'm not sure if the garage is trying to generate unnecessary work or if the steering rack is the root cause of the problem (quite a few years ago I did have to replace the engine).
Any advice or comments welcomed.
Thanks,
Andy
Thanks,
Andy
