The FIAT Forum
Old 19-05-2008   #16
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! New Zealand
Re: fuel comsumption
Something that Jai didn't point out about the 'ancient technology' of the Uno Turbo is that it is a multi-point injection system (one injector for each cylinder), which is more than can be said of the much newer 8V Punto models. Also I think the engine block dates back to 'only' 1969 But, of course, there are many changes.
I can't really think of anything 'ancient' about the Uno Turbo that holds it back compared to some modern development. Maybe not-having variable valve timing or variable-induction-length, both of which aren't relevant to a turbocharged engine? Meanwhile, Ford were still putting a pushrod motor into the Ka about ten years after the Uno Turbo was made (and 30 years after the SOHC FIAT motor made its debut in the 128), so surely that deserves the 'ancient' comment more? Maybe even the Uno 903cc deserves an 'ancient' comment since that had a pushrod motor - but FIAT came up with the goods by 1986 with the FIRE.
The Uno Turbo has a thoroughly-engineered (witness the oil cooler, piston underside spray-jets, water-cooled turbo, even an injector cooling fan though most are now removed!) and tough little engine. I actually think it is the most reliable of the Unos, not for its simplicity, but because of the quality of the engineering. Stuff is just bigger and better than on the other Unos - e.g. the ignition ECU is a proper mapped type with crank/flywheel sensors, not some little finned box on the distributor, the alternator is bigger and stronger, with an air-cooling duct, and the radiator takes up the full width of the air intake. I reckon the development engineers pulled out all the stops and fitted the parts that were kept out of the other models to save money!
I get an average of about 32-35mpg out of my Uno Turbo, with as much as 53mpg averaged on a long and gentle trip. When the economy is that good, you have to measure it against the performance available and consider the depreciation cost (loss in value each year) of other newer, possibly more fuel-economic cars. To me, the Uno Turbo seems an economical car when you get 0-100 in under 8 seconds and you take into account that it's hardly losing value at all these days.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 19-05-2008   #17
ZorAxe's Avatar
Trader Rating: (0)
South Africa
Thanks for the reply. If you compare an 1100 Uno and a Uno Turbo's fuel consumption, would you say there is a HUGE difference between the 2?
I know there is a lot of factors to consider, but im talking in general.
http://i105.photobucket.com/albums/m...xe1/newsig.jpg
Pioneer DEH-P5950IB
2x LA Bolt 12"
Targa TAG-4100C Amp
JBL CS300.1
ZorAxe is offline
Old 20-05-2008   #18
Trader Rating: (0)
well, my 1108 fire carburated uno, runs 32km/l at 130km/h on motorways, on city about 20km/l, but here the road don't have to much climbs, so i can't compare with some of you.
Fegco is offline
Old 21-05-2008   #19
ZorAxe's Avatar
Trader Rating: (0)
South Africa
Thats very good fuel consumption!
Pioneer DEH-P5950IB
2x LA Bolt 12"
Targa TAG-4100C Amp
JBL CS300.1
ZorAxe is offline
Instant Comsumption andyotoole Panda (New) 5 18-04-2008 15:43
(T) JTD in-tank fuel pump, fuel return? Dax Stilo 2 02-11-2007 16:45
Palio 1.9 D fuel comsumption noureddine Palio 0 21-09-2007 15:32
(T) Cinq Fuel Tank\ Fuel Guage arseofbox Cinquecento / Seicento 0 25-09-2003 02:35
