The FIAT Forum
Old 26-04-2008   #1
JRB21's Avatar
Trader Rating: (0)
South Africa
Engine Coolant Leak at engine
Hi, can somebody please help me.
I have a '95 Fiat Uno 1100 Fire.
My Radiator got a hole in the other day and my car overheated. I have fitted a new Radiator, but now there is a coolant leak on the engine.
When looking at the engine from the front. Just below the part where the exhaust gets fitted there are four round plugs, plug number 3 has a hole in and it leaks coolent. Any ideas on how to fix it?
JRB21 is offline
Old 26-04-2008   #2
Bandido A Maneira!!
bandido41's Avatar
Trader Rating: (1)
bandido41 has donated! South Africa
Re: Engine Coolant Leak at engine
Sounds like your core/welsh plug has gone it should be just a case of getting another one and replacing it, depending how handy you are with a spanner. Im not sure where in gauteng you are but if its anywhere near south joburg let me know and i can recommend a decent mechanic if you like.
All the arms we need are for hugging!
bandido41 is offline
The following user says "Thank You!" to bandido41 for this useful post:
JRB21 (26-04-2008)
Old 26-04-2008   #3
JRB21's Avatar
Trader Rating: (0)
South Africa
Thanks, but how do you get it out (with a spanner), it is round?
JRB21 is offline
Old 26-04-2008   #4
Cinq gone, Uno asylum!
1986Uno45S's Avatar
Trader Rating: (0)
1986Uno45S has donated! United Kingdom
You make a hole in it and then lever it out. One way is to punch a chisel into it and then use the chisel to lever against the engine. It's what's called an 'interference fit' so the core plug is just pressed into the block with a little bit of sealant around the edges. You will also have to 'drift' the new plug into place using a hammer and something like a big socket. It's not difficult if you take your time
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
The following user says "Thank You!" to 1986Uno45S for this useful post:
JRB21 (26-04-2008)
Old 26-04-2008   #5
JRB21's Avatar
Trader Rating: (0)
South Africa
Thanks for your help, will do so.
JRB21 is offline
Old 28-04-2008   #6
Trader Rating: (0)
i did one on a car by knocking it into the block and pulling it out with pliers
waynegts is offline
The following 2 users say "Thank You!" to waynegts for this useful post:
alexGS (10-05-2008)
Old 10-05-2008   #7
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! New Zealand
Might be easier that way to keep it square, plus you could always fish it out with a magnet if it drops too far in, I'm guessing
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Tags: , ,
vB code is On
Engine Oil, Gear Box Oil, Fan / Engine Coolant? 1.2puntosporting Punto 2 30-05-2007 22:13
engine coolant Shaun86 Stilo 1 20-01-2007 20:06
Engine Coolant PSYCHOSEI Cinq/Sei > Technical 19 18-01-2005 22:16
Engine Coolant jasper Stilo > Technical 2 24-11-2004 18:16
Engine coolant Neil Barker Stilo > Technical 3 23-04-2003 23:26
