The FIAT Forum
Old 25-04-2008   #1
Trader Rating: (0)
What gearboxes fit a 1.3?
Folks,
Just smashed up my 1.3 gearbox today, had 2 spares, but they're from 1108cc cars and neither will fit. So what gearboxes do fit the 1.3? Any ideas?
Tom
DickLexic is offline
Old 25-04-2008   #2
jjhepburn's Avatar
Trader Rating: (0)
New Zealand
Re: What gearboxes fit a 1.3?
Often they are the same, just different bell housing. If you are keen you could build a good gearbox using the inside bits of an 1108 box with the bell housing of your current box.
Just look to see if the gear linkage conenctions are the same, if they are then give it a shot
Note: the four and five speed boxes are very similar, they just have longer internal shafts, an extra chamber on the end, and obviously gears for fifth gear. If your 1108 boxes are four speed, just make a four speed box and dont bother with fifth gear (unless you are real keen).
Start with pulling your dead box apart (if nothing it will be an interesting exercise)
Current: 1987 Uno (1580cc), 1996 Bravo SX, 1990 mk1 Uno 45,and a 1973 Mini 850
Old: 1994 Punto 90ELX, 1984 Uno 70S, 1989 Uno 70SL, 1988 Uno 70SL, 1986 Uno 45 FIRE, 1987 Uno 45 FIRE, 1987 Uno 45 FIRE, 1989 Uno 45 FIRE, 1989 Suzuki FA50, and a 1980 Mini 1000
jjhepburn is offline
Old 25-04-2008   #3
Trader Rating: (0)
Casing from original box is ****ed, driveshaft munched itself and the box.
The other boxes look fine from a gearchange / clutch perspective, it's just the bellhousing pattern and starter motor size/location is the problem. Need to hit the scrap yards tomorrow and see what I can find, so just looking to see what other models should fit the 1301cc engine.
Old 25-04-2008   #4
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
The mk1 gearboxes fitted to the early 1116cc and 1301cc engines are the same as those fitted to the mk1 999cc FIRE engines. The differences are the bellhousing and final drive. The later 70SX models used an updated Strada based gearbox.
I looked at fitting a 1301cc gearbox to my original mk1 999cc FIRE so I could convert from 4 to 5 speed. However, the bellhousing also locates the gearshafts so it's a lot more hassle than just swapping it over as you have to have the right gaskets and ensure that everything is lined up. I think you have to check for endfloat as well.
Similar gearboxes were fitted to the Fiat Strada/ Regatta and also the Lancia Delta 1.3/ 1.5 engines as these used the same basic engines as fitted to the Uno. Other possibilities are the Fiat 128 models though I'm not sure if these were the same gearboxes. However, all these models are very rare and you'll be very unlikely to find one in a scrap yard.
Your other option is to look at the mk2 Uno and Tipo gearboxes fitted to the 1.4/ 1.6 models. These are evolutions of the 1301cc Uno engine but the 'boxes are quite different (hydraulic actuation and different linkages for a start). If you were to find a 1.4 Uno you should be able to swap the gearbox over with all the associated parts.
Sadly, most of the 1116cc/ 1301cc Unos have been wrecked by grass track racers so they are now virtually extinct. I doubt if you'll find any to take a gearbox from. In fact I've seen only three mk1 70SX's turn up on Ebay within the last year, one of which is now mine
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
Old 01-05-2008   #5
Trader Rating: (0)
Mk1 or Mk2 999cc?
Old 01-05-2008   #6
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
Originally Posted by DickLexic View Post
Mk1 or Mk2 999cc?
Mk1 999cc as I mentioned above. The mk2 999cc Unos used a later gearbox (the very last mk2's used a Punto based gearbox). There may be some crossing over but as far as I'm aware all mk2 Unos used a later type of gearbox compared with mk1's. I had a list of gearboxes used somewhere but can't find the list
Your best bet is to find a 1.4 mk2 Uno and use the gearbox/ linkages/ hydraulic clutch arrangement with you 1301cc engine. Simply because the 1.4 gearbox should be a lot easier to find compared with a mk1 1301cc gearbox.
Your last option is to use a Uno Turbo box, but again you'll have to swap over linkages/ clutch arrangements, plus the UT uses different driveshafts. On top of that the UT boxes are quite in demand and are more likely to fetch good money.
Once upon a time second hand Uno gearboxes were everywhere...
Old 01-05-2008   #7
Trader Rating: (0)
My engine code is 138B2, which apparently is from a Regata, would that have any bearing on what gearboxes suit?
Old 01-05-2008   #8
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
My engine code is: 149A7.000, which is a 1301cc engine according to the Haynes manual and so is yours. Both are listed as an engine fitted to the Uno. There were also 1301cc 127s, 128s, Stradas, Regattas and Lancia Deltas and Y10s (GTie model).
As I mentioned in a post above, the Regatta engine should also use the same gearbox. But you're still left with the same problem of actually finding one that's being broken for spares.
Basically most late mid to late 80's Fiat models using the 1116cc, 1299/ 1301cc and 1498cc ohc engines should use similar gearboxes, as do a couple of Lancias.
Old 01-05-2008   #9
Trader Rating: (0)
Back to plan A, see if I can get the original bellhousing welded. It's cracked the mount area off, and also smashed around the drivers side cv mount/face.
Old 04-05-2008   #10
Trader Rating: (0)
How about an X/19? What gearchange and clutch actuation do they have?
Old 05-05-2008   #11
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
The clutch actuation is similar (would need the lever swapping over, since the X1/9 one pushes in the opposite direction and is hydraulic) but the main gearbox casing is different because the gear selector comes out the other side... so I think that makes it a no-go for you.
Your best bet is to convert to an Uno Turbo gearbox (in my opinion) - the later Mk1-style ('top linkage') is to be preferred and there are probably quite a few around, as it's the same gearbox in the Mk2 Uno Turbo. This gearbox bolts on to the engine type you have (as it fits the 1301cc Uno Turbo or 1372cc Uno Turbo).
You'll need the driveshafts and hubs as well (they're bigger). And you'll need the gearchange linkage, as it's different (and better).
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
(G) gearboxes eric 83 Cinquecento / Seicento 2 26-02-2007 21:13
(T) what gearboxes fit mk2 1.2 8v? matty_oakley Punto 3 22-06-2006 19:53
Gearboxes Alex Leisure Lounge 1 21-04-2005 12:36
(T) gearboxes grover Bravo / Brava 0 14-04-2005 17:34
(T) Gearboxes arseofbox Cinquecento / Seicento 5 02-01-2004 03:57
