The FIAT Forum
Old 07-04-2008   #1
Trader Rating: (0)
Fuel Pump
Well i passed my test last thursday and had to wait all weekend to monday so i could get to armagh to tax my car! So car taxed i set off to clock up some miles staying close to home and then getting further away i collected my new wheel nuts, went to see if my cd player could be fitted! which it couldn't! and then just drove about for a while, then coming round a corner second gear then i accelerated away from the corner. Then to my shock discover that a whole colourful arrangement of lights on the dash! went to pull over no brakes went to accelarate no engine then realised the car was in gear and not shuddering! confused! anyway i was on a hill and it rolled to the bottom on a bad bend buses, cars, lorries steaming round the bend slamming on the brakes to avoid me! The car turns over but will not fire and a quick call to grandad and the mondeo to the rescue although i had to buy a tow poll! towed it to work the guys laughed and set about finding the fault everything is fine in the engine bay belts all good all narrowed down to the fuel pump in the tank nice brimmed this morning by me!
Anyway is this going to be a expensive job to fix?
I guess its back to the bycycle to work in the morning!
Ryan7733 is offline
Old 08-04-2008   #2
Fixin UnoTurbo I sleeper
Louie Bee's Avatar
Trader Rating: (6)
Louie Bee has donated! Netherlands
Re: Fuel Pump
Don't know about price, but if its the 1.0 / 1.1 / 1.4 SPI Non turbo Uno IE (with cat), its a case of
Moving the rear seats forwards, so you can see under the bit you sit on.
Move the carpet.
Remove the black plastic cover (2 screws)
Now you can see the top of the pump / level sender it has 2 fuel hoses and 2 electrical connectors.
Have a replacement pump before you remove the old one!
Don’t smoke when your car is full pf petrol fumes either.
Guess it’s a case of carefully removing the fuel lines -catch the leaking fuel!!! note which fuel line goes where. The 2 electrical connectors can't go back wrong as 1 is 3 pin the other 2. Remove them too
Now unscrew the nuts / bolts holding the pump in the tank. Don't drop them in (if you can). Make sure you have lots of ventilation as Petrol fumes isn’t good (perhaps lethal?? ).
Lift out old pump / level indicator unit.
Fit new one / second hand one WITH A NEW SEAL!!!!
Hook up and off you go
My fuel pump went down this morning so I'm hoping the above is true with a small price tag .
Good luck.
Louie.
Louie.
Now have aline of sight on finishing the MK1...
Just don’t know how long this line is
Louie Bee is offline
Old 10-04-2008   #3
Louie Bee's Avatar
Trader Rating: (6)
Re: Fuel Pump
Bit of an update..
Remove the petrol cap to ease any tank pressure before removing the pump - had a think about it before starting so I didn’t get a face full of fuel
Tie string to both pipes and the wires in case they drop down. I’d guess it will be a bugger to re find them if they drop down.
I removed the fuel pump to check if the rotor was just blocked / jammed..
Gave it a knock and connected it direct to the battery and... No Joy .
Scratched my head and tried it reverse polarity and hay presto Bzzzzzzzz then in forward Bzzzzzzz .
Put it back in the car and after priming a couple of times, locked up again.
So without removing the pump I reverse polarities it by removing the rear 2 pin connector and putting 12V the wrong way across the pins (with a fuse inline just try each way till you can hear it Buzzz), then reconnected the proper wire and got my car going.
Its now a bit hit and miss, so I think I'll need to remove it and flush the pump fully..
Till then I have the kit to reverse polarise the pump each time it fails.
This is the pump on the assembly which contains level sensor
However the Electric fuel pump can be split from the assy and serviced alone
This bare fuel pump (apparently) also fits "SYTEC REPLACMENT IN TANK FUEL INJECTION PUMP
FOR IN TANK PUMP MODELS ONLY
SUITABLE FOR THE FOLLOWING MODELS
BARACHETTA 1.8 16V (SRIS) 1998 - ON
BRAVA 1.4 12V 10/1995 - 10/1998
BRAVA 1.6 16V 1996 - 1998
BRAVA 1.6 IAW / 16V 5/1995
BRAVO 1.6 16V 1998 - 2000
BRAVO 1.8 16V 1995 - 1999
CINQUECENTO 1.1 SPORT >10/1994
CINQUECENTO S/SX 1992 - ON
COUPE 2.0i >4/1994
COUPE 2.0i 16V 4/1994 - 9/1996
COUPE 2.0i 20V >10/1996
CROMA 2.0i 16V >11/1992
CROMA 2.0i 16VB MOTRONIC >1993
CROMA 2.0i 8V 1990 - 11/1992
CROMA 2.0i LU 1990 - 1992
CROMA 2.0i LU >1993
CROMA 2.0i IE LE/LU 1985 - 6/1990
FLORINO 1.4i/MONOPOINT 9/1993 - 6/1995
FLORINO 1.5i/MONOPOINT 1988 - 8/1993
FLORINO 1.6i/MONOPOINT 9/1993 - 2001
MAREA 1.4i 12V 10/1996 - 2/1999
MAREA 1.6 16V 1996 - 1998
MAREA 1.6 16V BI-POWER 1997 - 1999
MAREA 1.8 16V 1996 - 1999
MAREA 2.0i 20V 10/1996 - 2/1999
PANDA 1000 IE / 4X4 1986 - 3/1997
PANDA 1100 IE / 4X4 / SELEC 1986 - 1992
PUNTO 85 1.2 IE 16V 1997 - 1999
PUNTO 90 1.6 IE 1994 - 1997
PUNTO 90 ELX 1996
REGATTA 75 IE 5/1987 - 6/1990
RITMO 75 IE 1.5 5/1987 - 1988
RITMO 90 IE 1.6 5/1987 - 12/1987
STRADA/RITMO 75 IE MONO-JET 1987 - 1988
STRADA/RITMO 90 IE MONO-JET 5/1987 - 12/1987
TEMPRA 1.4 IE/SW 3/1992 - 3/1996
TEMPRA 1.6 IE/SW 6/1990 - 1996
TEMPRA 1.6S MONO-JET 1990 - 4/1993
TEMPRA 1.8i 1990 - 3/1993
TEMPRA 1.8i 4/1993 - ON
TEMPRA 2.0i 4X4 3/1992
TIPO 1.4 IE 5/1989 - 3/1993
TIPO 1.6 IE/SELEC 3/1990 - 10/1995
TIPO 1.8i 16V 6/1989 - 1991
TIPO 1.8i 8V 6/1990 - 1992
TIPO 2.0i 16V IAW 1991 - 1992
TIPO 2.0i 8V 3/1990 - 1992
TIPO 2.0i IAW >1992
ULLYSSE 1.8 HL (COMPUTER) 1996 - 1998
ULLYSSE 1.8i SX/EL (NO COMPUTER) 1996 - 1998
ULLYSSE 2.0 HL (COMPUTER) 1996 - 1998
ULLYSSE 2.0 TURBO HL (COMPUTER) 1996 - 1998
ULLYSSE 2.0i SX/EL (NO COMPUTER) 1996 - 1998
ULLYSSE 2.0i TURBO SX/EL (NO COMPUTER) 1996 - 1998
UNO 1.0 IE SPI 1989 - 1994
UNO 1.1 IE 9/1989 - 3/1994
UNO 1.4 IE 1989 - 1994
UNO45 IE / FIRE / VAN 10/1987 - 3/1994
UNO 70 IE 9/1989 - 3/1994
UNO 75 IE / SELECTA 9/1987 - 3/1994
UNO FIRE 10/1987 - 1989"
I was Under the impression that the MK2 Uno with carb (1990 - 1992) has a mechanical fuel pump :S
Louie.
Old 12-04-2008   #4
Trader Rating: (0)
Re: Fuel Pump
I am waiting on my fuel pump coming from england! So hopefully should have it in work on monday or tuesday!
Ryan7733 is offline
Tags
uno
(T) JTD in-tank fuel pump, fuel return? Dax Stilo 2 02-11-2007 16:45
(T) fuel pump!!! johntra Bravo / Brava 13 29-03-2006 21:54
Fuel Pump Fast Finger Leisure Lounge 5 29-08-2005 19:46
(G) fuel pump flapster Uno 4 10-09-2003 23:31
