The FIAT Forum
Old 25-03-2008   #1
Trader Rating: (0)
Question uno turbo whining
Hi there,suddenly i am getting a whining noise when in second gear,both while accelorating and just slowing down to a junction etc...It did start doing this in third gear then stopped,now only in second gear
Has anyone got any ideas on what could be causing this?
wilko1977 is offline
Old 25-03-2008   #2
FIREsporting's Avatar
Trader Rating: (0)
FIREsporting has donated! United Kingdom
Question Re: uno turbo whining
Does is feel like it's loosing boost?
FIREsporting is offline
Old 25-03-2008   #3
F R O S T Y's Avatar
Trader Rating: (0)
Most likely its your gearbox thats whining mate. Does it have oil in it?
F R O $ T Y
"It Don't Matter if you win by an inch..or a mile...
Winning is Winning"
F R O S T Y is offline
Old 25-03-2008   #4
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
As Fro$ty says, check the oil gearbox level asap and before you do anything else. If you're lucky your gearbox is low on oil and just needs topping up. If you're unlucky you've got a bearing on the way out.
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
Old 26-03-2008   #5
Trader Rating: (0)
no lack of boost at all,was serviced not so long ago,so haven't really checked the gear box oil.
how easy is it to get to?can't you buy oil that can help quiet down the whine on gearbox?
Old 27-03-2008   #6
jbarragan's Avatar
Trader Rating: (0)
Greased Lightning gearbox treatment is good. they invented the ptfe treatment and thats what i always use, engine and gearbox. just makes changes a lot smoother. duno if it will stop a whining bearing tho.
josh
punto 85sx, 15" teamdynamic motorsports,lowerd 40mm,omp strutbrace, sportex decated straight trough exhaust,pipercross custom filter with cold air feed, fse fuel pressure regulator,civic 1.8 vti fuel pump, ported inlet manifold,polished ports, skimmed head, k1 10mm ht leads, ngk iridum plugs (9 heat range), oil catch tank, gates powergrip cam belt, QH water pump, WON 100bhp nos kit with progresive controller.
jbarragan is offline
Old 03-04-2008   #7
Trader Rating: (0)
used some gearbox treatment and has done the trick,no whining and change is easy.
Stated in a previous post about smoke from engine bay,if you open the bonnet it seems to be coming from the very back of the engine bay,as if under where the wipers sit??any ideas what it may be????
Old 04-08-2008   #8
Trader Rating: (0)
Could be the heat shield? Mine ended up with a couple of holes in it where the engine mount was worn out making the turbo pierce the foil and start to smoulder the wadding underneath?
DO NOT (as my idiot friend nearly did) try to put it out with a bottle of water!!!
floppermk1 is offline
Old 26-08-2008   #9
Trader Rating: (0)
Virgin Islands (United Kingdom)
its your diff it did it on mine then its cracked and came apart and oil pissed out all over my workshop floor
unoturbo1 is offline
various uno turbo mark 1/2 stuff (and punto, tipo, tempra, R5 turbo). christopher watson Auction Watch 1 30-07-2005 23:53
