The FIAT Forum
Old 20-03-2008   #1
Trader Rating: (0)
oil leak uno turbo
Hi there,bought my uno turbo recently,and have noticed a oil leak,just wondering what the main places are to check to try and find where it is?
With this when i am stuck in traffic steam/smoke comes up from the bonnet
wilko1977 is offline
Old 20-03-2008   #2
Trader Rating: (0)
South Africa
Re: oil leak uno turbo
I had the same problem, but don't know if that is your problem. My uno's compression rings were finished and the car started to breath and smoke (oil fumes) would come out of my bonnet when I drove in traffic. The car also leaked oil - oil being pushed out through the breather.
Just my 2c..
***Uno Turbo Chick***
chanti is offline
Old 20-03-2008   #3
F R O S T Y's Avatar
Trader Rating: (0)
The most common places oil spills from is the filler cap its a poor design on the mark 2s, dipstick (if the rubber is worn), rocker cover gasket (if its worn), Oil pressure sender can leak causing the oil light to flash up every so often, oil cooler pipes.
If you're getting smoke could be the turbo seals are worn i'm afraid, or check your breather piper is not blocked as has been mentioned already.
F R O $ T Y
"It Don't Matter if you win by an inch..or a mile...
Winning is Winning"
F R O S T Y is offline
Old 20-03-2008   #4
All Hail the Woodsman
thepottleflump's Avatar
Trader Rating: (0)
thepottleflump has donated! United Kingdom
Park in drive street and allow to start smoking then open bonnet to see where it's coming from. If it's overheating you'll probably need a new HG.
Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration)
www.strada130.com
thepottleflump is offline
Old 20-03-2008   #5
Trader Rating: (0)
Cheers for the replies,if it is the turbo seals,is it an expensive job?
The car does not overheat at all,pulls well in every gear,but is quite noisy sometimes in different gears.
Old 21-03-2008   #6
Trader Rating: (1)
Id start by cleaning all the engine and bay, underneath with a jetwasher, then see if there any external leaks, sounds like oil dripping on exhaust, Ant!
antsuno2 is offline
Old 03-04-2008   #7
Trader Rating: (0)
Question Re: oil leak uno turbo
have cleaned a lot of the engine bay,and has cut the smoke down due to oil being cleaned off,but have now noticed that the smoke comes form the back of the engine bay,roughly under where the wipers sit???
(T) Oil / Coolant leak / turbo pipes / remap ! DEISELDAVE Grande Punto 9 04-02-2008 13:00
Turbo oil return line leak MLTGuzzi Spider 0 07-01-2008 04:21
(T) 1.4 Turbo engine oil leak Blue MK2 Uno 3 15-09-2007 11:18
(G) Uno 45 Sting oil leak Brymak Uno 2 23-11-2004 12:42
