Thread Tools
Old 07-07-2004   #1
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Uno Engine Swaps
Ok guys and girls, I'm new here and it's good to find other fans of the Uno who like fiddling with them!
I'm interested to know if anyone has done engine swaps to upgrade the performance. I'll discount the turbo engine, as though it is a fine unit it would be a bit of a nightmare to swap into a standard car! I'm looking more at the older carburetor models or single point injection units, that with the right tools and facilities can be swapped in a day.
Obviously if one had a FIRE engine, then the 1100 FIRE should swap in place of the 1000 (mk2 60S models had 1100 as standard), and the Punto 1250 engine should also swap over. Some of the Cinquecento boys have already gone down this route.
What about the 16V engine from the Punto Sporting? Is it based on the FIRE engine?
In the UK at least, the biggest engine was the 1400. Europeans got a 1500 version, which I think I am right in saying is the old Strada/ X19/ Lancia Delta engine.
If one had the 1100 (non FIRE), 1300 or 1400 engine, then the 1500 should be a direct swap.
I've also been looking at the 1600 Tipo engine and it looks like an update of the old 1100/ 1300/ 1400 engine. Has anyone swapped a Tipo 1600 into a Uno? The Tipo 1600 pushes out 85 bhp and nearly 100 ft lbs of torque. That's not too far behind the 1300 turbo engine but without the complexity!
Don't get me wrong, nothing can substitute the kick in the back that the awesome turbo can give, but with the weight (or lack of) of the Uno 85 hp will be a LOT of fun. Especially in a very standard looking car!
Anyone who's done engine swaps with their Uno's please share the info, and also was the performance gain worthwhile?
Chas Uno is offline Reply With Quote Quote
Old 10-07-2004   #2
New Zealand
I'm lineing up to have a go at wacking a 1600 tipo engine in my uno 60, but I'm slightly lacking in funds at the moment, I'm putting 40mm lowered springs in it at the moment, and I need a new Warrent Of Fitness next month, and I think it may need some work, but if you do attempt this, I'm keen to know how you get on.
Slinkylinks is offline Reply With Quote Quote
Old 14-07-2004   #3
Slinkylinks, I haven't tried swapping a 1600 Tipo engine into a Uno, and I am also not 100% if the engine would fit or not.
I'm assuming the 1600 engine was an update on the 1500, of which the 1500 was available to some European market Unos but not the UK. They updated the 1300 to a 1400, and it looks similar though the distributor has been moved to the end of the camshaft rather than at the lower front of the engine.
However, maybe some of the Fiat gurus can confirm whether the 1600 engine is an update on the 1500? If it is, then it should drop straight in place of an 1100 (not FIRE), 1300 or 1400.
It won't be as quick as a Turbo, but will sure give some modern cars a fright! 85 horsepower in a car so light would give a substantial performance gain. I reckon you'd have close to Citroen AX GT performance.
Am tempted to try myself, though as my car is a FIRE engined version the wiring and mountings might be different. If I had a non FIRE 1100 version I would be sorely tempted to do the swap, as old 1600 Tipos can be bought off Ebay for less than a new suspension kit!
Old 16-07-2004   #4
i've had an engine swap done from a 999cc engine to a 1372cc turbo i.e engine and i can tell u for a fact that it is piss easy to do if you know what you are doing.
[8D]F R O $ T Y
DONT MESS WID DA T.K.K!!
F R O S T Y is offline Reply With Quote Quote
Old 16-07-2004   #5
frosty me old mate from turbocollective yeah? ;)
Dunc
Standing 1/4 mile at Santa Pod - 14.63 @ 94.57mph
Dunc Maclean is offline Reply With Quote Quote
Old 17-07-2004   #6
Easy Dunc how u doin mate, yeh itz me da same FRO$TY off Turbo Collective. Neva used dis site b4, seemz a bit quiet on ere
[8D]F R O $ T Y
Old 17-07-2004   #7
yeah it is. need to get more of the T.C. boys on here cos it the only place i got a pic of my car on de net [:P]
Dunc
Old 17-07-2004   #8
Wouldnt wana be behind that flame mate!!! Probably end up flame grilled like a whopper from burger king!!! LOL Looks the Dogz b*ll*cks tho...
[8D]F R O $ T Y
Old 17-07-2004   #9
hehe cheers frosty mate ;)
Dunc
Old 18-07-2004   #10
Frosty,
There's a number of people on this forum that have enquired about dropping the Uno Turbo engine into lesser models, so maybe you can give some pointers and advice as to what's involved?
Physically, we all know the engine will drop straight in with the correct mounts. However, the Turbo has many additional parts that weren't fitted to the rest of the range.
Did you have a donor car to transplant everything over? Or did you just drop in the engine?
How about the wiring? Did you swap over the turbo wiring harness? How did you incorporate the the ECU and control units? Did you use the turbo fuse box as it has a lot of extra relays attached?
Also of note is that the turbo had brake disks at the back and vented at the front. Did you upgrade your brakes to Turbo specification?
How about the suspension? The Uno 45 has a much lighter engine, so the front springs at least would need to be upgraded to cope not just with the extra weight but also the extra performance!
And which driveshafts did you use? The standard Uno items or the Turbo shafts which are a 'split' type design on the drivers side?
Did you fit the turbo anti-roll bar? Is this a straight swap onto the standard Uno crossmember? Or did you swap the entire turbo crossmember into the 45 shell?
I've done engine swaps in the past (2.8 Granada V6 into a Mk3 Cortina for instance!), and know how awkward a job like that can be at the best of times. If one had, say, a rusted but mechanically sound and complete donor turbo, then I would suspect it is a simple case of swapping everything over, including all the suspension, brakes and wiring looms. The basic Uno shell is the same as the turbo, so then again I'm assuming that all the mounting points for addition items such as fuel pumps, intercoolers and oil coolers are already incorporated into the shell.
Perhaps you could share with the forum how you did it, and whether you had to source the additional parts or started off with a complete donor vehicle. Did you do all the conversion yourself?
If it's as easy as you say it is, then I'm sure there will be a few people on this board on the lookout for a donor turbo after finding out what exactly is involved!
Lastly, I would say to anyone considering doing this that they should upgrade EVERYTHING to suit the turbo engine. Just dropping in a turbo engine into a base model would be a lethal combination. Suspension and brakes must be upgraded or else you'll have a car that won't handle or stop safely. Back in the days when I was involved in 'hot rodding' (yes, I'm that old!) it was pretty much a golden rule to make a car stop and handle better BEFORE increasing the performance. There isn't much point in making a fast car if it can't put the power down on the road properly or stop safely from higher speeds.
Lastly, do you have any pictures of your turbo conversion Frosty? If you do, is there any chance you post them up here so we can see what the end result looks like? I'd love to see them so I can see what I can convert my 45S into one day!
Old 19-07-2004   #11
Hey 1986Uno45S (sorry dont know ur real name) Yeh i started off with a Donor vehicle, it was a 1992 written off mark 2 uno turbo which i spotted by chance, Had full service history on it so i took a chance and bought the entire car off the bloke for a measly 200. Your right in assuming that brakes and suspension need to be upgraded. Like you say you cant just drop in an engine without changing everything else, that would be deadly as you say!! I swapped the rear axels of my 1.0 litre uno to that of the UT which as u say has rear brakes, Also changed the front brakes, Changed all the suspension, wiring loom, Ecu the lot. I dont actually have an Anti Roll bar on my uno but i'm planning to have one fitted to it soon. I didnt actually do the work myself but i've been told that cos the basic uno shell is exactly the same as the Turbo it makes life easy to mount everything back in place, its a matter of stripping out the whole of the car and then replacing everything else back in again. The most difficult part of the whole job was probably feeding all the wires from the loom into the engine bay cos if u see the size of the hole in which they must be fed into you'd be like WTF??? lol
I have got pictures on my site if you wana take a look, Its at www.geocities.com/ukoutlaws and theres also more of my car on the www.turbocollective.co.uk website
If you're not a member of Turbocollective u should sign up cos it is one of the best uno sites on the net. So check it out,
PEACE [8D] F R O $ T Y
Old 19-07-2004   #12
Just to elaborate how straight forward it was the guy who worked on my car managed to do it in exactly 5 days! although he couldnt get it to start until a few days later due to a burnt out ignition coil! If you are gona do a conversion the best way is to get a donor vehicle cos least that way it dont cost a fortune on parts, Otherwise its probably better to just buy urself a decent Uno Turbo although they are very hard to come by these days. The Tipo 1.6 engines another good conversion, i was even considering it at one point, i've heard they are a straight swap for the 1.0 litre engine but not sure how true that is.
[8D] F R O $ T Y
Old 20-07-2004   #13
Hey Frosty,
I checked your site - nice car! And you have some good ideas in action there! Good luck with the forthcoming mods.
Black would be a great colour if you get it resprayed, it looks mean but in a kind of stealth like way. A pig to keep clean though, just ask ChrisUnoman! Red is good too (my Uno is red) but a lot more visual! However, red would be better as you wouldn't have to worry about doing the engine bay/ door shuts/ inner panels as well. Unless you're going to strip the whole car down again, I'd go for red, though black would look really good.
The way you did your conversion was the way I would recommend anyone else considering undertaking a turbo project. Start off with a complete donor car and transplant everything over.
There's a lot of people who think that just dropping in a turbo engine is all that is required. They forget or don't realise just how many other parts need to be changed as well to make it all run correctly. And as the turbo has some serious performance it is crucial that suspension and brakes are upgraded to at least turbo spec.
I don't see why any competent mechanic couldn't do the transplant themselves with the appropriate tools. Maybe it will take a bit longer than the five days yours took, and that was done by professional mechanics. Like you said, strip everything out of the new shell and swap everything over from the donor turbo car.
A base model 45/ 60/ 70 three door shell is the same as a turbo, and as far as I can tell all the mounting points for the extra turbo parts are already in place. However, as the turbo came out in 1985, I wonder if maybe early cars didn't have these extra mountings. Then again, I doubt if there are many (if any!) pre 1985 Uno's left! And the ones that are could well be too rotten to even consider a turbo conversion!
It seems that I have the oldest Uno on this board as no-one in a previous posting had one older. Mine was first registered in May 1986 on a 'C' registration and is surprisingly in good shape for it's age. The doors were rusty, but apart from the odd spot or two the shell is remarkably rust free. If I had access to a donor turbo car like you I'd seriously think of doing a turbo conversion. Unfortunately with my finances in the dire straights they are in it's not looking very likely, and I kind of like the miserly fuel economy that the 1.0 FIRE engine gives me for the moment!
Then again, you were incredibly lucky to find a complete donor car for 200! Looking on Ebay I've seen knackered and non running turbo's go for more than that.
As for the 1600 Tipo engine, I'm pretty sure it is simply a larger capacity version of the 1.4/ 1.3/ 1.1 (non FIRE) engine. No-one has confirmed this yet though. I also think that the same 1600 engine was fitted to Lancia Delta's and also the Fiat Tempra (a Tipo with a boot really). There was also a twin cam version of the 1600 engine fitted to these cars though that could well not be suitable for a transplant. I don't know if they are based on the single cam engine.
If the 1600 is just a bigger version of the 1.4, the conversion should turn out to be VERY simple in comparison to a turbo conversion. Starting out with say, a 1.4, it is simply a matter of pulling out the old engine and then dropping a Tipo 1600 in it's place. All the mounts should be the same, and all the wiring should hook up on the bigger engine along with the fuel lines, throttle cable, exhaust etc. The existing Uno gearbox should also bolt straight up too, and I suspect that the Tipo box could well be the same as the Uno but with a different final drive. Saying that, a Uno 'box would probably have a lower final drive which would really help with the standing start acceleration!
In short, I reckon the swap could be done in an afternoon, it should be that simple. It would also work out as a very cheap way of upping the performance without too much work.
On top of that I wouldn't have thought it too necessary to upgrade brakes and suspension, though it would be adviseable. Going by the Tipo 1600 performance figures and bearing in mind that the Uno is quite a bit lighter, I reckon on achieving a top speed of around 110 mph (maybe a bit more) and a 0 - 60 time in the 9 second bracket. What really would improve would be the engine midrange performance due to the extra torque of the 1600. The 40 - 70 mph time should drop quite dramatically, and there should be loads of grunt in most of the gears without having to rev the engine to the upper end of the rev range.
It's a very healthy performance gain, though as it is quite a bit less than the turbo the standard brakes and suspension should cope reasonably well. The turbo really does have so much extra performance that it would be essential to upgrade suspension and brakes to suit.
However, the swap would NOT be quite so straight forward if the Uno used for the conversion had either the OHV 900 cc engine or the 1000 or 1100 FIRE engines. The OHV and FIRE engines are totally different engines to the 1600. Silly little things like the throttle cable, distributor, and engine electrics being in different places would make it just that little bit more awkward. That's not to say it couldn't be done though, just that it would require more work and transplanting of additional parts. Alternatively, swapping over the engine bay wiring loom and engine brackets for that of a 1.3/ 1.4 engined Uno would solve this problem.
FIRE engined Uno's can take advantage of the Punto engines though. The 1250 engine is a straight swap (for a fuel injected Uno 1.0/ 1.1), and with a bit of extra work the 16 valve 1250 Sporting engine should fit also. Some of the Cinquecento owners have already done these conversions. What is worth bearing in mind is that some of the Punto's use Multi Point Injection systems whereas the Uno only used Single Point Injection. That would mean extra work in incorporating the MPI system into the Uno's wiring loom.
A shame there doesn't seem to be anyone on this board who has actually carried out either the 1600 or 1250 FIRE conversions. They could give everyone else pointers and advice. Maybe I'll have to give it a go myself once I get out of debt!
Oh, you mention that you don't have the anti roll bar fitted? It was a standard fitment on the Turbo, and some later 1.4 i.e.'s. All Uno's have the mounting holes on the track control arms, though it's not clear if the roll bar brackets will fit on the front crossmember/ body mounting points. There seems to be an extra bolt hole required, but I haven't been able to find a roll bar with brackets to try this out. Maybe some of the other non turbo owners have fitted a turbo roll bar to their Uno's?
Lastly, you are right in saying that getting all the wiring from the fuse box to the engine bay looks impossible! There's just that smallish hole with a rubber grommet to put everything through. It's like as you say - WTF?!!!!!
So good luck with your turbo Frosty, it's nice to see someone down south doing a serious Uno turbo project. By the way, is there anywhere in London that the Uno fans hang out?
Anyway, I've written enough here. Oh, I wasn't christened 1986Uno45S! I'm known as 'Chas'.
Chas 'the impoversions 45 owner'!
Old 20-07-2004   #14
Hey Chas thanks for the comments, about the colour i've decided to go with Ferrari Red, i saw it on an mr2 and fell in love with the colour and like u say it also cuts down the cost of a respray as i wont be spraying all the interior door panels etc. I've also managed to get hold of a full hormann widearch bodykit for 200 second hand which i i'm having fitted to the beast! Bargain of the century!! that kit costs 1400 brand new from avanti motorsport so i'm well chuffed about that!!:) Although this will hinder performance due to added weight it looks the absolute dogs b*ll*cks mate! Keep checkin my site, i'll post some pics when its complete. I was originally going to go for Black but was advised against it as Turbo'd cars need alot of cool air and black attracts far too much heat and like u say they are a an absolute nightmare to keep clean!! Surprisingly the 1.4 turbo engine is very good on petrol!! 10 for example would give me half a tank which can last up to a week depending on the way i drive. But if i put the bleed valve up that although it increases the performance a lot it also increases the fuel consumption, so i only use it when its needed! Like you say a full turbo conversion can be quite expensive, It would've been more sensible for me to sell my car and buy an uno turbo but to hell with that...theres no fun in that is there?? lol the way i see it lifes too short so might as well enjoy it!! I dont know if theres anywhere the uno boys hang out in London but we are all organising a meet down WestonWheels on the 29th of august through our club www.turbocollective.co.uk. Its for all owners of the uno even non turbos so if you can u should try and make it down with us. Can u imagine how kool it would look with loadsa unos rolling down together on the motorway?? Also we're all planning to go southend together although no dates been confirmed as of yet!
Well i think i've typed enough as well now!! lol
Take it easy mate
[8D] F R O $ T Y
Old 27-07-2004   #15
Hey Fro$ty,
Yes, I didn't think of that regarding heat and the colour of a car. Black is the worst colour as it absorbs it all and is not very good at dissipating it! And a turbo engine generates a LOT of heat. Best go for red then!
Not sure what the Hormann body kit looks like. Must admit that I'm not a fan of bodykits, but that's because I grew up in the 80's when there were some AWFUL kits available for cars like the mk3/4 Escort. They made a hideous car look even more hideous! And they even came up with kits for the Capri that made a nice sleek design look disgusting. It really was the decade of no taste! However, there are some good kits out there, but they were always very expensive. Sounds like you've got a bargain on your hands from one of the better body kit manufacturers.
Me, I've always been a fan of Street Sleepers. That's why I shoe horned a 2.8 litre V6 into a totally standard looking mk3 Cortina many years ago. From the outside you couldn't tell, apart from the fact that it was lowered a bit with wider alloys and tyres. But if you listened carefully, you could hear that it was no four pot engine under the bonnet! Most people thought it was a nice conditioned Cortina on first glance, so boy racers didn't try very hard at the traffic lights. Then I put my foot down and by the time they realised that it was a non standard Cortina I was well away - great fun!
I still have the car but it's not on the road. 150bhp and 170 ft/lbs of torque is no big deal these days, though the Cortina is quite a light car so perfomance is no slouch. However, the 2.9 litre quad cam 24 valve Cosworth V6 (from last of the mk 3 Granadas and also the Scorpio) is a straight swap. That gives 220bhp without any modifications! But the fact that I have to run a 1.0 litre Fiat now gives you an idea of what state my finances are in, so a project like that is out of the equation.........
I must admit that I would have done all the turbo conversion on your car but left the outside looking like a standard Uno 45. Can you imagine how many people you could shock like that?!!!!!! GREAT fun!
Oh, you mentioned that it could have been wiser to buy an original turbo rather than doing all the work on your car. I disagree! The newest Uno turbos you can buy are going to be 10 years old or more, and will certainly need work. By doing your car as a turbo project you've done all the work as necessary while doing the conversion. I reckon that unless you can find an immaculate turbo that's been looked after you'd still have to spend a lot of money on it to bring it up to scratch, and the end result would probably cost the same as yours anyway.
Plus, doing your own project gives you the satisfaction of creating a car to your own specifications and to have it how YOU want it. That makes the car that much more special.
By the way, what/ where is WestonWheels on the 29th August? Sounds like fun, but would my 1.0 be able to keep up with the turbo boys?!!!!!!!!!!!
And fancy Southend still being a meeting ground for cars! Last time I went was many years ago, when it was populated by XR2 and XR3's, Astra GTE's, Opel Manta's and Ford Capris. I'm probably revealing my age now..... lol!
Anyway, gotta get to bed now.
G'night!
Chas
Thread Tools
(T) New Punto Power Steering & Engine Management Fail shotter Punto (Mk2/2b) 17 30-12-2006 12:45
(T) Problem.....RED Engine LED always on..... :( tubi Punto (Mk2/2b) 7 28-02-2006 13:48
Engine Cleaning (Engine not in car) arseofbox Lets Talk FIAT 3 17-06-2004 04:30
(G) Engine swap question... sabeltandcavia Panda (Classic) 23 05-12-2003 01:20
(T) Engine Swaps....again!! arseofbox Cinquecento / Seicento 5 18-11-2003 02:41
