| | #2 | |||
| Re: Expertise Please??
I meant the filler cap surround. Any clue to how to get the backing plate off. Cheers Al
__________________ Mk1 Uno Turbo in progress! | ||||
| | #3 | ||
| Re: Expertise Please?? This is tricky!! took me a while to get mine off, (as you cant buy them anymore) soaked it in weasle piss (wd40)) a few times, the outer ring acts as a clip and is exposed to the inside wheelarch and gets covered in mud and crap, so blew the crud out and scraped it off (with high pressure air line) more wd40, and you have to gently tease it off by pressing the little tabs at the back and levering the ring, i used a plastic spreader ( or credit card) to jam under the ring, (oohh!!) to protect the paint and a mini screwdriver, and a plastic trim tool, took me a while and wound me up a bit but had to come off as holds the filler neck in, but perseverance will win!! Ant!
| | #4 | ||
| Re: Expertise Please?? There is a white plastic ring on the inside. You need to take that off (its easy just use a screw driver and flick it off). Then carefully push the outer ring off from the inside (it has 4 tabs). I totally agree with the last comment, that the first step should be to clean the inside of the wheel arch. This is for two reasons; 1 you can see what you are doing, and 2 sometimes dirt gets trapped in the system and means the clips dont work. To clean it just use soapy water, a brush, and a hose. Be careful as the plastic can be brittle and the part is hard to replace. If you do break it then its not the end of the world. Its not a load bearing structure so you can fix it with super glue.
__________________ Current: 1987 Uno (1580cc), 1996 Bravo SX, 1990 mk1 Uno 45,and a 1973 Mini 850 Old: 1994 Punto 90ELX, 1984 Uno 70S, 1989 Uno 70SL, 1988 Uno 70SL, 1986 Uno 45 FIRE, 1987 Uno 45 FIRE, 1987 Uno 45 FIRE, 1989 Uno 45 FIRE, 1989 Suzuki FA50, and a 1980 Mini 1000 | |||
| | #5 | ||
| Re: Expertise Please?? Thanks for the input. I had a go and broke it. Ahh well. Il have to try and get a new one. It was a beeatch to get off. It is impossible to get it off without breaking the clips. Its weird il post a photo. Nice one Al
| | #6 | ||
| Re: Expertise Please?? it can be done, so far I have tried to do it 6 times and I've been successful 3 times 50% aint bad
| | #7 | ||
| Re: Expertise Please?? I took my time as you cant buy them anymore, it came off in the end!! with a lot of fiddling, Ant!
