| Another Idle Problem - Please help A slight variation on the other idle problems: I have a '94 Uno Pacer 1400 with twin choke Weber carb. Occasionally (hot or cold), idle drops to about 3-400rpm (from about 1000) and sometimes cuts out. The car starts again immediately, but may or may not idle. I can control it with a bit of throttle, but it gets tricky doing the toe-heel thing in heavy trafic. In all other respects, the engine is behaving perfectly. Speaking to the local Fiat dealer, he immediately said "vacuum advance", so I duely replaced it to no avail. I suspect the carb's idle control valve or the idle sensor. Anyone ou there know how to test it?
| Re: Another Idle Problem - Please help If it is a sensor controlled engine then your have to check the throttle position sensor...... I hope that it wont be in a proper tuning....... Regards, Jeyakar.T
| | Aksunen | Uno | 3 | 26-07-2005 15:42 |
| Tip timing problem? | Akeldama | Tipo | 4 | 01-08-2004 05:54 |
| Mid-throttle injection problem in Lancia Y10 | FatNote | Panda (Classic) | 26 | 30-07-2004 18:58 |
| [Tipo 1.6 ie 94] Injection light and idle | Malex | Tipo | 1 | 28-07-2004 21:18 |
| | Grim_Evil | Cinquecento / Seicento | 9 | 03-07-2004 01:21 |
