| SMoke help there is smoke wen i boost and there oil leaking some were in engine bay making smoke to any ideas y oil is leaking every were thanx
| Re: SMoke
| | #3 | ||
| Re: SMoke Ok thank you i will check this out tomoz can u tell me wat could be making the smoke wen boosting please thank you
| | #4 | ||
| Re: SMoke usually turbo oil seals, maybe blocked breather, piston rings or stem seals, head gasket, if headgasket your water & oil will probibly mix so youl find oil in the water and water in with the oil if you take the pipe off from the airflow meter to the turbo you will be able to fit your fingers in the turbo and check for play, if there is lots of play then id say turbo
| | #5 | ||
| Re: SMoke I fixed the prplem wid some Purpose Fix that cills all craks an sill the gasket no more somke for mean time so must have bin a small leak in gasket
| | #6 | ||
| Re: SMoke turbine seal leaking hemm....like BBQ house
| Smell + smoke from heater..!! New 100hp.. | medlow | Panda (New) | 15 | 15-10-2007 20:40 |
| | Multiplewagon | Stilo | 24 | 01-03-2007 00:59 |
| If your car exhuast was pumping white smoke. but | cduuffo13 | Leisure Lounge | 6 | 20-12-2006 19:36 |
| | fbarcode | Marea | 41 | 30-03-2006 16:38 |
| | ashleyjewitt@fsmail.net | Cinquecento / Seicento | 4 | 21-02-2006 20:44 |
