| ePER version for my uno
| | #2 | ||||||
| Classic Uno Obsessive | Re: ePER version for my uno If it is indeed a mk1 Uno then you'll have the same problem that I have! Eper doesn't seem to cover the mk1 Unos other than a model called the "Uno CS" (1988-89), and the Uno CS wasn't offered with the 1299/ 1301cc engine. What I've been doing is looking up parts for either the Uno CS or the later mk2 Uno models (1989 onwards) on Eper. For general parts such as the running gear the mk1 and mk2 models were basically the same. The problems come when trying to find a mk1 only part, such as a gearbox oil seal like I was trying to order this week. Some engines and most gearboxes were different between mk1 and mk2 so you can't use the later part numbers. If you can find a dealer with a microfiche of Uno parts then they will have the parts you need. But if you get a new Fiat dealer like in my town then they are pretty much hopeless. If it's not listed on Eper then as far as they are concerned they can't get it ![]() What part are you looking for?
__________________ ![]()
| | #3 | ||
| Re: ePER version for my uno my uno is from 1990 with weber 30/32 DMTE. based on haynes databook, my engine type is 149 A7.000 OHC. i'm looking part for front stabilizer which is not equipped when i purchase that car from a friend. and some other parts like coil, distributor etc.
| | beau | Uno | 142 | 21-09-2008 21:19 |
