| how to replace steering joint? hi again, i got my steering rattle and clonked when came overbumps or gravelish road. after a brief check, i found lower steering shaft coupling joint (thing look like a cross joint) was a bit shot. mine is uno70s '91. i already got this joint but still figure out proper way to install. anyone have experience in replacing this bit?
__________________ eagle flies alone | |||
| All Hail the Woodsman | Re: how to replace steering joint? 1. Buy Haynes manual 2. Read haynes manual 3. Follow instructions. If you can't get Haynes in Jakarta, hunt around with the search function.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #3 | ||
| Re: how to replace steering joint? thanks, pottleflump. i have it, but as far i can read and understand the manual, this can be done by removing all upper steering components (wheel steering till coupling shaft and pinch bolt). and about getting the joint on its place, is it easy way slot-in? im not sure but i'll give it a go.
| | #4 | |||
| Classic Uno Obsessive | Re: how to replace steering joint? If you mean the 'joint' that connects the steering column to the steering rack then yes, you disconnect the upper steering components. This is actually quite simple going from memory.
It should be a fairly simple job so take your time and good luck! Chas
__________________ ![]()
| | scottytoohotty01 | Punto | 0 | 24-04-2007 13:31 |
| | cyberplayer | Punto | 0 | 27-03-2007 19:56 |
| Power steering | Helz | Polling Station | 44 | 20-07-2006 17:29 |
| | Big Black Stilo | Stilo | 33 | 11-07-2005 17:08 |
