| sunday jobs on the UT!! well again ive been messing in the garage! firstly gave the hf turbo calipers and carriers another coat of hammerite! shiit bit was cleaning them up, its downhill now!, then the misses said she can see oil spot on drive, so had a look and level was down (never moves) and looks like has been seeping out of the weak seal in the filler cap, (put a bit of tape around till source new seal) then i wiggled a few pipes as usual, and the fecking crankcase breater snapped, easily fixed just chopped off the brittle end, (but was under the afm) I would advise all uno owners to have an inspection under the bonnet before the real damp and cold comes, a squirt with a little weasle piss (wd40) never hurt an uno and will keep the damp out! Ant!
| Re: sunday jobs on the UT!! SHAME!!! the delta that was broke, was a mint shell but not the same as integrale so had to go, but he made me remove a few bits!!! Ant!
| | #3 | |||
| Classic Uno Obsessive | Re: sunday jobs on the UT!! Hmmm, Delta convertible! Calipers are looking good Ant! But does Smoothrite hold up on them when they get hot?
__________________ ![]()
| | #4 | ||
| All Hail the Woodsman | Re: sunday jobs on the UT!! Did you spray the calipers or brush paint them? My Stilo had hammerite painted brakes and never had any issues with the paint smoking/melting when worked hard.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #5 | ||
| Re: sunday jobs on the UT!! Did you block the brake pipe holes
| | #6 | ||
| Stripped | Re: sunday jobs on the UT!! i painted my uno brake calipers smooth red, still need to test them
__________________ ![]() Uno: 16" Alessio Monzas, Toyo Proxes, -35mm Lowering Kit, 3.5" Peco, De-Locked, Recaro Seats, Stripped, Induction Kit, Wide arches, Clifford G5 | ||
| | #7 | ||
| | #8 | ||
| Burninator of threads! | Re: sunday jobs on the UT!! filler cap (oel) is just an oring isn't it? as for the dodgy breather, yeah, they die eventually. when I get a new shell for mine i'm gonna replace every bit of breather/pipe on the engine, i mean its 17yrs old, and rubbe rdont' cost much so worth it. what happened to the delta? looks rust free, but has a slight case of convertab'itus
__________________ ![]() Volvo for Life | ||
| | #9 | ||
| Re: sunday jobs on the UT!! He only bought the delta as a spares car (56kish and mint) as all his trim ie seats, carpet, windows, and virtualy all the plastics on his grale were crap, and he wanted me to cut out sections of the sill where they rust and the roof, I painted them in smoothright as have in the past, I'm on the 3rd set with the same tin! and have not had an issue of the paint burning, flaking, dulling ect, and i put tissue in the holes so as not to block them, 3rd coat to be applied in about an hour, i'm sure i heard somewhere that a punto oil filler cap fits the uno and is a better design maybe i'l try that, Ant!
| | #10 | ||
| Re: sunday jobs on the UT!! previous work, uno turbo calipers, Ant!
| | #11 | ||
| Re: sunday jobs on the UT!! Well yet again i was called back to the U'T, fix it again TONY!! i noticed last week she was low on water, then on saturday i went for a spin and the drivers footwell was wet! (misses noticed nowt he he) so i thought the windscreen needed sealing with the non hardening flexible stuff! (like dum dum if anyone can remember that) as i did my golf a few weeks back, which had 2 waterfalls running down the footwells, (developed after removing and refitting screen) now alls well! anyway the rubber was dry, HMMM!! then i dipped my finger in the water and it tasted sweet (ANTIFREEZE!!!) so off came the under dash tray and trims, shine a light , and eh presto the heater matrix valve is dripping from 2 places,i dug out my spare which had the same rusty water marks on so wont be fitting that! I rung fiat today and ordered the new valve £20 and o-ring £4? and a couple of exhaust rubbers, the 2 big central rings and the next one towards the rear £10 and will have them for tomorrow, another sunday fiddling but finished for starwars!! can you see the drip! Ant!
| | #12 | ||
| Experinced life risker | Re: sunday jobs on the UT!! Good work ant, i miss messin about with the uno. Got so much on at the minute ive had no time for it. Got some money behind me now so gonna try get some stuff done to it over winter | ||
| | #13 | ||
| Re: sunday jobs on the UT!! Sunday! Sunday! i'l fix the heater valve and sort the exhaust rubbers out, first drained the water from the matrix, then removed valve and tried refitting the new valve, and guess what! its the wrong part!!!! so glued my old valve and refitted ( and not one drip) my mate who works as parts manager in salford has left and things aint going right, i rang caledonian and told him it didnt fit he said there are 2 types and the part i want is no longer available, (i dont think he tried) as i phoned perrys and told him the part number on the packet the valve came in and he said is wrong and will send me the right one, shows you eh!! if this valve comes and is correct i'l be speaking to caledoian, so wednesday it comes but i think il save the knuckle scraping fun for SUNDAY!!! its like peeling an orange in your pocket fitting this valve, and wait for the car to cool down first as i got red hands draining the water he he the exhaust rubbers went well!! see the difference in where the valves connect to the matrix, the right one has a recess for a seal and the other is just flat so it wont seal! Ant!
| | #14 | ||
| Stripped | Re: sunday jobs on the UT!! nope but its gettin driven by my dad a few miles hopefully so i can test things like brakes, the paint on them and etc. as he's moving house and ant those calipers are so nice! lol i just left mine on and painted them haaha you did the real deal
| | #15 | ||||||
| Back once again w'the... | Re: sunday jobs on the UT!!
I enjoyed reading your posts with your trademark wit! Shame I haven't had much time to spend around here lately, but then again my Uno Turbo is running great and hasn't needed any work - though I did change the cambelt & tensioner as a preventative measure a couple of weeks ago.Cheers, -Alex
| Rat Progress Today (Sunday 6th) | default_user | Panda (Classic) | 2 | 06-05-2007 21:44 |
| | antsuno2 | Uno | 0 | 25-09-2006 20:20 |
| bloody road works at 8:20am on a sunday?! | arc | Leisure Lounge | 3 | 29-01-2006 21:04 |
| | Emm | Cinquecento / Seicento | 10 | 13-11-2005 21:15 |
