Hi There i have fitted the 1.4 IE Turbo enegine in my 1.1 shell just need a question is this ok in the shell i have or will it all twist on me wen i drive as i have wired anything up yet thank you
As far as I know the chassis themselves are all the same althoug if your gonna to be using it very hard might be worth seam/stich welding it whilst it's all apart...
The turbo shell is exactly the same as a bog standard 45. The suspension and brakes are another matter entirely. You MUST change them unless you want to end up wrapped round a lamp post
