gholian
Member
On my MK1 Uno Fire 1L the needle has always pointed to 70 degrees on the temperature gauge under normal driving conditions. Being stuck in traffic the temperature rises to a little over 90 and the fan cuts in. The interior fan that blows hot and cold air into the car stopped working about two months ago and I had to change it for a new one. In doing so I had to drain the coolant and take out the heater core. When I put everything back together the temperature started to rise to about 80 degrees while driving under normal conditions. I changed the thermostat, the water pump, made sure there was no air in the system, flushed out radiator etc.... but to no avail. Since I changed the thermostat (genuine Fiat) the temperature needle now rest half way on the gauge at 90 degrees. I brought it to my local mechanic and he thinks that is normal but now when I stop in traffic the fan cuts in after less than a minute surely this is not normal? Can anyone advise?.
