The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Old 02-05-2004   #1
minislapper has donated!
Engine mountings/cam cover !
Ok....think Freddy's engine mounting rubber thingies are pooped. The engine moves all over the place and the rubber looks very perished.
How easy are they to change ??? They don't look very complicated. Any tricks to doing it ??
Also, he's got a massive oil leak from the cam cover. I'm presuming the gasket has seen better days. Is it just a case of undoing all the bolts and replacing the gasket or is it slightly more tricky than that ??
Ta muchly :D
Freddy >> 1988 Uno 45S
minislapper is offline
Old 02-05-2004   #2
Trader Rating: 1
Morty Mort has donated!
Norway
Engine mounts - have no idea.
The gasket is just to slip and slide into place. Just unbolt and rebolt the cover. Get someone to find the appx. correct torque.
Morten.
abarth wheels & steering. ia lowered. pg audio. refurnish.
projects: air intake. (used) seats. exhaust-repair. legal tint.
Morty Mort is offline
Old 02-05-2004   #3
Italy
Doing the mountings is relatively easy...if it's the right one (driver's side for UK cars) put a jack under the oil sump with a wooden block to avoid metal to metal contact and then unbolt the failed mounting!About the gasket there's nothing more to say;)
Passion has neither brands nor models!
La passione non ha nč marche nč modelli!
(Quite happy dark met. blue Panda driver!)
Enzo is offline
Old 03-05-2004   #4
Righto. I'm used to working on cars.....just not Fiats !! Thought things would be relatively easy. Was just checking to see if there were any handy hints. Sounds straightforward enough. Ta :D
(G) Uno Engine Swaps Chas Uno Uno 31 01-03-2008 09:58
(T) Problem.....RED Engine LED always on..... :( tubi Punto 7 28-02-2006 13:48
Engine protection cover (underside) John_K Ulysse 7 07-11-2005 20:25
Engine Cleaning (Engine not in car) arseofbox Lets Talk FIAT 3 17-06-2004 04:30
(G) undetermined engine in a 81 Fiat Spider 2000 RESAT Spider 0 07-06-2004 09:33
Copyright ©2002 - 2010 FIAT Forum
