fiatdonor
Such a long time since I was building Uno based kit cars. Have just renewed rear calipers, discs etc. My query is the operation of the self adjusting mechaniscm. Once the piston has engaged with the pin on the back of the pad, how can the piston adjust for pad wear as it is locked to the pad and therefore cannot turn on the handbrake helical screw rod? If the piston is screwed all the way in and the slack taken up by pumping the brake pedal, how does the slot in the piston "find" the pin on the back of the pad? My senior moments are on the increase!
