| rear disc brakes uno turbo can anyone help me how do u adjust hand brake just fitted new pads now handbrake doesnt work well
| | #2 | |||
| Back once again w'the... | Re: rear disc brakes uno turbo Hi there, welcome to the forum - great name, used to be my MSN name back when I used to post on the Turbo Nutters forum When you changed the rear pads, you would have wound the pistons back in (clockwise)? Generally I find this is easiest if you slacken the handbrake cable right off first. Then, I wind the pistons in, assemble the calipers and pads, operate the footbrake a few dozen times, and finally retighten the handbrake cable. This results in a great handbrake - for me, at least. Assuming that you got the pistons wound in OK, presumably if you now slacken the cable, operate the footbrake, and retighten the cable, things will be better. Cheers, -Alex
| | #3 | ||
| Re: rear disc brakes uno turbo thanks i will try that today
| | beau | Uno | 142 | 21-09-2008 21:19 |
| | antsuno2 | Uno | 8 | 26-11-2006 14:12 |
| Ten of the Best? | alainax | Leisure Lounge | 16 | 04-08-2006 01:03 |
