The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Uno > Uno > Technical
Old 12-02-2007   #1
Trader Rating: (0)
South Africa
Waterpump? Timing belt? Tensioner? Noise
Hi Guys
Been a while since my Uno gave me hassles. Been visiting the forum to keep educated.
My car: yr 2000 Uno Mia (3 door) 1.1.
My broblem: I hear a high pitch noise/sound/whistle coming from the timingbelt/drivebelt area. Could this be my waterpump packing up? the sound is getting louder and lasting longer. this also happens when the car is cold and when I increase the revs slowly and gently. it normally last 'till the engine is warm. the noise also happens between 20-60km per hour.
Also could you guys give me an idea of what is the best way the change my timing belt.
Many thanks....
Aldino is offline
Old 13-02-2007   #2
Trader Rating: (0)
Re: Waterpump? Timing belt? Tensioner? Noise
Is that one of those fancy new Brazilian made Uno's?
Sorry, no techy advice - only got a 13 year old model
1.4 ie S in metallic blue.
Gearchange God
5doorturbo is offline
Old 14-02-2007   #3
Trader Rating: (0)
South Africa
Hi
Not sure if it's Brazillian but it still have an 1100 FIRE engine.
Aldino is offline
Old 14-02-2007   #4
premrajeev's Avatar
Trader Rating: (0)
India
Hi there,
Well, this is a simple problem, nothing to worry much about.
All you have to do is change your drive belt to the alternator / Airconditioner (if fitted).This belts slips occationaly and causes this whistling noise. This happens all the time with all my cars..
And ,as the timing belt and pulley's are slotted, they'll not slip until they break off..So changing the timing belt is not required unless it's real old..
Hope this helps..
Rajeev
Fully Restored !!
premrajeev is offline
Old 15-02-2007   #5
Trader Rating: (0)
Hello,
I too had similar problems with my UNO45 earlier.
But, in my case it was with Water pump bearing.
Anil
aa80616 is offline
Old 16-02-2007   #6
unonumero's Avatar
Trader Rating: (0)
unonumero has donated! United Kingdom
hey, my water pump packed up all ready, i have a new one sitting waiting to go in.
I don't really have a clue where to begin to replace it and i heard that whistle the other day, im going to go and work on it this weekend so if people could help me - sorry im im hijacking your thread!
Uno: 16" Alessio Monzas, -35mm Lowering Kit, 3.5" Peco, De-Locked, Recaro Seats, Stripped Out, Clear Punto Side Repeaters, Induction Kit, wide arches, Clifford G5
Near Future : 210 White Respray with Black roof, MK1 UT Rear end and Turbo Interior
unonumero is offline
Old 16-02-2007   #7
oldskoolmk1unoturbo's Avatar
Trader Rating: (0)
best way to change the waterpump is from the top, it is awkward and takes time but i did it recently in my mk1 turbo,
oldskoolmk1unoturbo is offline
Old 04-03-2007   #8
premrajeev's Avatar
Trader Rating: (0)
India
HMM--
I have seen a detailed guide of how to change the waterpump - in the guides section. All though it was not uno's , was completely similar can defintely of use to you.
I had mine replaced by the help of that quiet easily. U can work on the top, but some nuts are easy to be removed from the bottom.
Rajeev
Fully Restored !!
vB code is On
Stilo Abarth Timing Belt Change johns Stilo > Technical 15 05-11-2006 13:56
When should my Seicento Sporting Cambelt be Changed? pippypower Cinq/Sei > Technical 14 28-10-2006 14:31
timing belt maybe ?' jdf Punto 11 18-10-2006 19:01
1998 1.2 16v timing belt iainand Punto 1 17-10-2006 22:24
Goaning noise from new timing belt bjw105 Punto > Technical 5 24-09-2003 01:20
