| Uno Turbo MK1 Engine in a MK2 How easy or difficult would it be to drop in a turbo mk1 engine into a mk2 shell? Or would it even be a problem? I dont know how much difference it would make (despite the fact that I've had both a MK1 and a MK2.) I love the uno I have, but might be looking for something bigger in the future, so I was thinking about the possibility of a re-shell. Plus, decent looking uno turbos are expensive although most that I have seen are sound engine wise. Cheers guys.
| | #2 | |||
| Back once again w'the... | Re: Uno Turbo MK1 Engine in a MK2 SteveNZ has done it. He used a combination of Mk1 block and Mk2 intake system (and turbo), but I am sure that a complete Mk1 setup will fit absolutely fine. The differences between the Mk1 and Mk2 bodyshells are cosmetic details - or at least, they don't affect the mounting of the engine. There are some mechanical differences, like the clutch (usually hydraulic, but the holes will probably accept the cable set-up) and the fuel pipes (they run under the car for the Mk2, if I remember correctly. You'll need to change all these anyway I suspect!) You'll also need the gearchange lever and linkages, and don't forget all the other Turbo details - driveshafts, brakes, steering rack, etc... it's a big project, but all bolt-on stuff. -Alex
| | #3 | ||
| | #4 | ||
| Re: Uno Turbo MK1 Engine in a MK2 Fit a MK1 turbo into a MK2 Shell. Just an Idea.
| | beau | Uno | 142 | 21-09-2008 21:19 |
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
| anyone know if a mk1 punto gearbox off a 1.2 fits a mk2 1.4 turbo uno engine?? | mike215 | Lets Talk FIAT | 7 | 19-10-2005 09:39 |
| | Dima | Uno | 3 | 15-08-2005 11:00 |
