| 2 CARBs hello.. if i will put on uno 1100 2 Carbs it will give more power?
| Re: 2 CARBs what kind of carbs? weber 40 dcoe or something?
__________________ Be smart, drive safe, stay legal. www.rs-team.prv.pl www.tuning.opole.pl | |||
| | #3 | ||
| Re: 2 CARBs i think he means the twin choke carb off the 1108cc uno. If so, then yes it'll give you a little, though im not sure on teh compatabilites of the swap
| | #4 | |||
| Back once again w'the... | Re: 2 CARBs The last time I looked, the 1108cc Uno had only a single-barrel carb ![]() I think if you fit twin carburettors, you would need a camshaft change to notice much improvement. -Alex
| | #5 | |||||
| Re: 2 CARBs
maybe the old uno 60 - with teh 1116 engine?
| | #6 | |||
| Re: 2 CARBs
i'm going to fit twin carb from 125p to my uno 1.0 but first i'must finish uno turbo....
__________________ Be smart, drive safe, stay legal. www.rs-team.prv.pl www.tuning.opole.pl | ||||
| | #7 | ||
| Re: 2 CARBs
__________________ 1400 uno pacer sx, 15" mags, free flow, induction kit, ut front brakes,50 HP NOS nitrous kit. still sorting out rear disc brakes from old RIP uno. | |||
| | #8 | |||||
| Classic Uno Obsessive | Re: 2 CARBs
That looks excellent! Any more info on how it was achieved? I wonder if any more work was done on the engine to get the speedo running almost off the end?!!!! Alex is right, it was only the older 1116cc non-FIRE ohc engine that had a twin choke Weber fitted (Uno 60S). The FIRE to my knowledge never had a twin choke carburetor fitted as standard. It can be done, but you'll need to have a custom inlet manifold made up, plus possibly a custom throttle cable. I have a twin choke Weber from a 1.3 Uno. Wonder how much work it would take to get it to fit my 1.0 litre FIRE?
| | #9 | ||
| Re: 2 CARBs what about fitting 4 carbs? any one tryed it b4? | |||
| | #10 | ||
| Re: 2 CARBs well you can maybe fit 1100 bike sidedraughts,but dunno if it's gonna work.
| | #11 | |||||
| Re: 2 CARBs
| | #12 | |||||
| Re: 2 CARBs
Forget motor bike carbs. They are too difficult to set up and you won't find a lot of people who can do it. A few people have converted FIRE engines to twin choke carbs.
| | #13 | |||
| Re: 2 CARBs
__________________ 1400 uno pacer sx, 15" mags, free flow, induction kit, ut front brakes,50 HP NOS nitrous kit. still sorting out rear disc brakes from old RIP uno. | ||||
| | #14 | |||||
| Re: 2 CARBs
| | #15 | ||||||
![]() The Uno 60 1116cc and 70 1301/1299cc both had the twin-choke carbs (Weber 30/32 DMTE or the agricultural-looking but smooth-running and reliable (in my experience!) Solex C32) Neither of these carbs will fit the FIRE engine unless you make up a manifold adapter. And, in these days of fuel injection, I just don't think it's worth the bother! To prove how sad an individual I am, I can tell you that I once connected to the 'net and ended up at the MSN home page (browser default). Lead news article: "Are Carbs Really Bad?" Why yes, I thought, fuel injection is more accurate and reliable any day. Little did I know the article contained dietary advice. As for the AWESOME work on that Mk1 Uno - I laughed out loud when I saw the oval white dials! - yes, they must have raised the gearing somehow I think to get the speedo that far around with the engine not even at the end of the redline... my Uno 60 used to run off the tach with it's 128-Coupe camshaft. Twin carbs are definitely more worth the trouble than fitting an (old, worn-out) twin choke Weber, in my opinion. My 128 Coupe actually started easier and ran more economically with its twin DNCFs than with the original twin-choke carb. One other thing - though it may not be a major drawback (I've seen engines running OK with them) - most carbs for RWD cars like the 125p have the float chambers oriented differently so that the fuel will not surge during cornering. Turn them 90-degrees and put them on a transverse engine, and you may just have problems. I know of a 128 with IDFs fitted that didn't run very nicely on the track because of this fuel surging. I think you're best off with the DCOEs or the DCNFs. -Alex
| | mase | Cinquecento / Seicento | 43 | 12-11-2005 15:45 |
| | KHALooD | Uno | 15 | 26-05-2005 19:33 |
| Motorcycle carbs on cars | AIJ29 | Leisure Lounge | 4 | 17-03-2005 11:24 |
| | faster4_tec | Punto | 2 | 30-11-2004 13:33 |
| Carbs for panda | pandarally | Panda (Classic) | 3 | 15-08-2004 16:21 |
