The FIAT Forum
Old 10-12-2005   #1
Stevh0's Avatar
Trader Rating: (0)
South Africa
Brake Upgrade?
Guys when fitting Slotted and Grooved disks ,
is it necesary to do the rear aswell? Afaik its a 80/20 brake bias anyhow?
Im sure it would probably just be a waste of money for the rear?
Maybe just move the front disks to the back??
EP82 Starb0 GT Turbo
1100 Uno Mia
Ex Uno Turbo 270hp
Ex Uno Turbo 190hp
Stevh0 is offline
Old 10-12-2005   #2
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated!
Re: Brake Upgrade?
All I would reccomend is checking they are working! Check disc thickness and pad wear. Check the caliper works and use the time to clean up and oil the handbrake mech.
Hellcat is offline
Old 10-12-2005   #3
Trader Rating: (0)
New Zealand
Re: Brake Upgrade?
The bias is not a set ammount. It alters with rear suspension height. Because of this they put some adjustment into it. You can adjust it if you like. I had mine adjusted too high at one stage, it would always lock the rears.
SteveNZ is offline
Old 11-12-2005   #4
Stevh0's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
Hey steve .. i remember a while ago on my previous Ut , I took the Sound out the boot , and went to the track .. fek coming down the back str8 the rear ends kept locking up like madd!
So u guys reckon .. just some slotted disks front and back?
apparently the Drilled and slotted disks crack .. .. Daymm they look good tho ..
1100 Uno Mia
Ex Uno Turbo 270hp
Ex Uno Turbo 190hp
Stevh0 is offline
Old 11-12-2005   #5
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Re: Brake Upgrade?
Get grooved and dimpled...
Grooved and drilled discs can crack but I dont think it happens that much. If you want to be safe then either use grooved only, or grooved and dimpled.
As long as they are vented then you shouldn't need the drilled part.
Hellcat is offline
Old 11-12-2005   #6
Stevh0's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
but the Drilled grooved disks looks oh so .. SEKZI! :P
1100 Uno Mia
Ex Uno Turbo 270hp
Ex Uno Turbo 190hp
Stevh0 is offline
Old 11-12-2005   #7
M@nticore's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
hello my fellow uno drivers, i've got a question to ask, does the 1600 palio calipers and disks fit straight onto the uno or do you have to mod them to fit. The one oke here in SA installed palio front brakes on his UT. Thanx
oh and check out these nice disks, they look so nice!!!
www.powerbrake.co.za
M@nticore is offline
Old 11-12-2005   #8
Stevh0's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
hey thanx bro , now i know where i can get disks from?!!!
dude are u on the abarth forum?
1100 Uno Mia
Ex Uno Turbo 270hp
Ex Uno Turbo 190hp
Stevh0 is offline
Old 11-12-2005   #9
M@nticore's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
No Not yet, can I register if i drive a normal uno, still busy with my UT project.
I drive an 1100, installed the UT torsion bar, UT front brakes, UT rear brakes, i just need to sort out my engine on this car while i'm still busy with my project. if you've got any parts around i could perhaps use let me know, will buy them.
those disks realy look nice, they are a bit expensive but, i think it's worth it. pitty they don't make it for the rear, know it won't make a big difference but just for looks.
Old 19-03-2006   #10
Stevh0's Avatar
Trader Rating: (0)
South Africa
Re: Brake Upgrade?
yes you can ..
1100 Uno Mia
Ex Uno Turbo 270hp
Ex Uno Turbo 190hp
Stevh0 is offline
(G) AP Racing Big Brake upgrade... comedydill Bravo / Brava 9 19-10-2008 00:45
(T) Punto brake upgrade, and a question.... keri-WMS Punto 2 21-11-2005 21:19
Brake upgrade Glyn Panda (Classic) 3 19-05-2005 22:22
(T) Punto GT brake system upgrade Aghini Punto 0 03-03-2004 05:49
(T) Brake Upgrade bhoywondar Punto 1 25-01-2004 01:45
