The FIAT Forum
Old 28-06-2008   #1
Trader Rating: (0)
UNO 1242cc Petrol ECM
i have an UNO 1242cc petrol version 2000 model, for few days i am having problem with the injection system due to which i am getting injection system failure lamp in my dash..
this problem has made driveability of my car very very poor, it misfires quite often, but he engine start in the cold condition is excellent, problem arrives only when i drive, i have to increase the engine rpm frequently so that the engine doesn't stall...i am fed up of this problem..its embarassing too.
can there be problem with the ECM???? and what are the symptoms if the complete ECM is gone???
please help me guys
ashar786 is offline
Old 28-06-2008   #2
Trader Rating: (0)
Question UNO 1242cc Petrol ECM
what are the symptoms if the complete ECM is gone?????
ashar786 is offline
Old 28-06-2008   #3
Cinq gone, Uno asylum!
1986Uno45S's Avatar
Trader Rating: (0)
1986Uno45S has donated! United Kingdom
Re: UNO 1242cc Petrol ECM
Problem is that the 1242 injected Uno was not available in the UK so not many people will know the system. It's possibly the same as the Punto/ Cinquecento SPi system but otherwise I don't know. It does sound as if you need to take it to someone who can plug a computer into the ECU and then read the fault codes. That way you'll be able to pin point where your problem lies.
Good luck!
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
Old 29-06-2008   #4
Trader Rating: (0)
Question Re: UNO 1242cc Petrol ECM
Good luck!
Thank you dude, yes, i have hangered my car in the dealer's service station but not yet diagnosed, but the service has hinted that there might be a problem with the ECM.. is it possible..??? what are the signs if the whole ECM unit has gone..?? My car is having Central fuel Injection which is also called MPFI and has the electronic carburettor.
ashar786 is offline
Old 29-06-2008   #5
All Hail the Woodsman
thepottleflump's Avatar
Trader Rating: (0)
thepottleflump has donated! United Kingdom
If the whole ECU is gone the car won't run at all. I remember speaking to an RAC man and he told me 90% of ECUs sent for repair / replaced as faulty aren't. The problems you exhibit could be any manner of things, a faulty sensor, dodgy HT leads, dodgy Dizzy cap, dodgy injector....
Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration)
www.strada130.com
thepottleflump is offline
The following user says "Thank You!" to thepottleflump for this useful post:
alexGS (30-06-2008)
Old 29-06-2008   #6
Trader Rating: (0)
thanks buddy, thats what i was thinking, i hope the problem isn't the ECM , the ECM is a costly affair, FIAT has already stopped producing this model long time back in India, getting an ECM would be.
Hey can u tell me whereas MAP sensor, lambda sensor and throttle positioning is located, and how come my engine starts good when cold and doesn't stall when idle??? only when i drive i face problem..??
ashar786 is offline
Old 30-06-2008   #7
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! New Zealand
The ECM may be interchangeable with a later model like the Palio.
thepottleflump gave very good advice in the post above. The injection light coming on is most likely to be a side-effect of a minor ignition problem such as spark plugs, ignition leads. The lambda sensor (we'll assume your car has one, it may not) 'reads' the exhaust gas, so if a spark plug doesn't fire, it causes the lambda sensor to report the wrong mixture in the exhaust, and then the injection warning light comes on, even if there is nothing wrong with the injection system!
Ignition problems are more noticeable under load - when the engine is idling unloaded, weak spark plugs may be sufficient, but when the load comes on, they stop firing. So given that this is what you described, start with the basics (spark plugs, HT leads) and work your way up to the MAP sensor/throttle position sensor etc. later.
For a description of the part names, see your other thread - please try not to double-post!
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
The following user says "Thank You!" to alexGS for this useful post:
ashar786 (30-06-2008)
Tags
ecm
(G) Faulty ECM?? please help!! d1888b Bravo / Brava 7 05-09-2007 09:27
(G) How to make a 1242cc petrol faster ! chris_VW_1987 Punto 40 11-05-2007 16:22
(T) Punto 1.4 ECM Replacement cost Nickyg Punto 1 14-07-2005 09:09
(G) Petrol Slurper Uno 60 Brymak Uno 2 06-07-2005 00:15
