| | #1 | |||
| Back once again w'the... | I finished off a little project that I've had in mind for a long time. See http://www.youtube.com/watch?v=aQhXF6xYu44 Cheers, -Alex
| Re: Slight modification to the switchgear lighting awww its not workin Alex ![]()
__________________ Peeing off the whole planet one person at a time![]() TURBO SEICENTO FOR SALE | |||
| | #3 | ||
| Re: Slight modification to the switchgear lighting same here | |||
| | #4 | ||
| Re: Slight modification to the switchgear lighting ok it worked, but ican't understand??!! | |||
| | #5 | ||
| Re: Slight modification to the switchgear lighting cool did you use the led colour changing ones like on ebay? nice one gav i wanted red ones in my uno
__________________ ![]() Uno: 16" Alessio Monzas, -35mm Lowering Kit, 3.5" Peco, De-Locked, Recaro Seats, Stripped Out, Clear Punto Side Repeaters, Induction Kit, wide arches, Clifford G5 Near Future : 210 White Respray with Black roof, MK1 UT Rear end and Turbo Interior ![]() | |||
| | #6 | |||
| Back once again w'the... | Re: Slight modification to the switchgear lighting Video seems to be working fine? I used red LEDs for the hazard and rear fog light switches. I used an orange LED for the heated rear window switch. White LEDs for the front fog light and the 'mystery switch'. But I couldn't decide what colour to use for the lights/wiper switch markings themselves - so I used colour-cycling LEDs These were a few dollars each from Jaycar (www.jaycar.com). I believe that Jaycar is now open in the UK?-Alex
| | #7 | ||
| All Hail the Woodsman | Re: Slight modification to the switchgear lighting
__________________ Alfa Romeo 156 GTA / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #8 | ||||||
The colour-cycling LEDs were very difficult to get working right. First, I referred to the datasheet available from the website, and I calculated the resistor value (R = V / I) with V = 12 - 2.13 (forward voltage required), and I = 0.023 (forward current required, 23mA). That blew up the first LED. ![]() The forward voltage drop varies slightly for each colour, so a one-size-fits-all resistor didn't seem to be possible for 12V. I could get the red, the green, and the blue, but the next three colours are supposed to be red+green, green+blue, and red+blue - I got red, green+blue, and red... the final colour is 'white' (red+green+blue) and again I would just get red. Increasing the resistor value (to dim-down the LED as desired) would just stop the colour cycling completely; I would only get red! So the final solution involved wiring two red LEDs and a 300 Ohm resistor in series with the colour-changing LED (series wiring brings the voltage down), and then wiring the second colour-changing LED in parallel with the first. This is a lot more complicated than normally necessary: the white LEDs, for example, just have a 1k Ohm resistor in series with each one, and most other LEDs require a 300 - 560 Ohm resistor in series. I had to wrap the colour-changing LEDs in white insulation tape, to reduce their intensity. You might wonder why, based on the video, but remember that is a camera - in real life, the switch legends lit up the car otherwise! If you are putting LEDs behind the crystal-clear lights/wipers legends on the Uno, you're generally better off with normal-intensity (i.e. diffuse coloured) LEDs; otherwise the black background starts to glow! High intensity works better for the square push-switches which are quite diffusive by the white material used. In my experience anyway - I've done four Unos now! Be aware that white and blue LEDs are special cases - if you decide to use these, be prepared to experiment with resistor values (and buy a few spare LEDs). Green, yellow, and red LEDs are a fraction of the price and much more tolerant of current and voltage. Basically, you need a handful of 560 Ohm resistors (a few pence each?) and five LEDs (for a standard Uno), plus some spare speaker wiring etc. and some heatshrink tube (two sizes, one to fit over the LED leads, and one to fit over the LEDs themselves). This makes the LEDs a press-fit into the switch housings, which are designed to accept the fibre-optic end fittings standard on the Turbo and 70SL (and probably used on the Abarth 130TC as well )-Alex
| | #9 | ||
| Re: Slight modification to the switchgear lighting Really cool Alex many of my background lights dont work so i was considering led replacements. Hope thoe are regular leds as i may have quite a few lying around. You saved me the research.
__________________ Nissan a/d wagon, Mitsubishi lancer mx touring 2.0l turbo engine swap, Honda partner wagon, Fiat uno! This car is fun. I'm getting to work on all its vital organs. | |||
| | #10 | ||
| Re: Slight modification to the switchgear lighting Nice work Alex i'm impressed!! hehehe F R O $ T Y
__________________ "It Don't Matter if you win by an inch..or a mile... Winning is Winning" | |||
| | #11 | |||
| Back once again w'the... | Re: Slight modification to the switchgear lighting Thanks Frosty! See attached pics. I've been cruising the streets ![]() More accurately I drove to Auckland and spent an hour and a half in a traffic jam - not cool - I don't know how people live up there... ...then it started HAILING and lashing down as hard as you can imagine so that the wiper couldn't cope, the roads flooded (giving the underside of the Uno a good wash) and I couldn't see any road markings, ended up somewhere completely different from where I was trying to go (Pt. England instead of Pakuranga, if nzdownunder's reading!) The Uno coped really well with all this (hopefully the carpet underlay's not soaked ) and though I missed the shop that closed an hour before, I did eventually get to the second place I was trying to go, to drop off $30-worth of old Amiga monitor, and drive home.Cheers, -Alex
| | #12 | ||
| All Hail the Woodsman | Re: Slight modification to the switchgear lighting Alex Alex Alex, please tell me that's a inspection lamp under the car and not something else..........you were checking for signs of rust after your wet road trip right ![]()
| | #13 | ||||||
![]() I'm surprised that Chas hasn't replied yet. -Alex
| | #14 | ||
| All Hail the Woodsman | Re: Slight modification to the switchgear lighting The LED upgrade to the dash is cool and like the orientated button for the neons nice touch LED is definately on the list for the Strada if I ever get time to get the restoration off the ground.
| | #15 | ||
| Re: Slight modification to the switchgear lighting If I did the led thing I wouldn't need to try and find a replacement bulb for the fibre optics. I put an ordinary bulb in (4w) and while it works it is not bright enough.
__________________ A Euro convert now:73 Rover P6B (on restoration) 84 Uno, 92 Saab 900s vert, 93 Saab 9000 CD, 96 Saab 900s, | |||
| mk2b footwell lighting need soem help plz | joshua.watson1987 | Punto > Styling | 29 | 27-11-2006 20:03 |
| For Sale: FIAT PUNTO SX 60 1.2 98 SUBTLE MODIFICATION (FIAT Punto) | PeteyPye | For Sale / Wanted | 0 | 04-11-2006 14:23 |
| Change of Lighting | Alan.D | Panda (Classic) | 69 | 07-09-2006 11:27 |
| Recommended modification | tubi | Punto > Technical | 2 | 07-11-2003 19:13 |
