| wheel width i have a Uno 60S and i'm thinking of changing the wheels. i know that the sizes that fit are 15s on 195/45 and 14s on 185/50 or 55, but what about the width of the rim? 'cause there are a lot of sizes, like 5.5" , 6.0" , 7.0"... which one works?
__________________ It might be that your only purpose in life is to serve as a warning to others. | |||
| BLUES+TWOS! PANDA+UNO! | Re: wheel width on the 15" rim, with a 195/45 tyre, you want a 6.5 inch width wheel, which will slightly rub on the gearbox on full right lock
__________________ ![]() THE MODERATOR FORMERLY KNOWN AS TURBONED 'that my friend, will mash up through the engine block of a Fiat Uno, no problem I'm Andy McNab, I'm Andy McNab, I'm Andy Mc Nab, I'm Andie MacDowell ummmmm... YEAH BUT JAJA BINKS MAKES THE EWOKS LOOK LIKE F*****G SHAFT!!! | ||
| | #3 | ||
| Re: wheel width ok, thanks for the quick reply! also forgot to mention that it's the mk2 uno.
| | #4 | ||
| 3rd Gear Spins Anyone? | Re: wheel width ive got 195/45/16s to fit with no rubbing ![]() Dunc
__________________ WANTED - COUPE 20VT ALLOYS Owner of a standard Mk2 UT.........well, maybe not | ||
| | #5 | |||||
| Re: wheel width
| | #6 | ||||||
| Cinq gone, Uno asylum! | Re: wheel width
| | #7 | ||
| | #8 | ||
| Re: wheel width well ive done a few mods, mainly with a hammer ![]() lol but i dont really want to go into what i did to make them fit nicely...they only rub on full lock
__________________ ![]() Uno: 16" Alessio Monzas, -35mm Lowering Kit, 3.5" Peco, De-Locked, Recaro Seats, Stripped Out, Clear Punto Side Repeaters, Induction Kit, wide arches, Clifford G5 Near Future : 210 White Respray with Black roof, MK1 UT Rear end and Turbo Interior ![]() | |||
| | #9 | ||
| | #10 | ||
| Re: wheel width dont forget they will be closer or rub on the rear subframe if you have drums on the rear, so may need spacers
| | #11 | ||
| Re: wheel width well i bypassed the rear subframe problem ![]() Its easy, just cut a section out of the subframe, then weld in back in back to front so instead of it sticking out due it being circular, u get a concave curve in which doesnt rub
| | #12 | ||||||
| Fiat Wheel Trim Question | Reaver23 | Punto | 19 | 1 Week Ago 18:06 |
| Cento Lean or something more sinister... plus weird wheel vibrations? | GhostWKD | Cinquecento / Seicento | 23 | 17-05-2007 06:48 |
| sports steering wheel insteed of original steering wheel | vdhi | Punto > Technical | 7 | 18-04-2006 12:12 |
| MAREA steering wheel remote 2 SONY adapter finished .... | Struja | Marea | 3 | 29-04-2005 09:03 |
| Qualification in Wheel clamping | Charlotte | Leisure Lounge | 18 | 01-12-2004 16:15 |
