Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Detecting miniscule coolant leaks with a cold Uno<!-- google_ad_section_end -->
Published by Louie Bee
07-05-2006
Unrated
User Rated:Unrated
Talking Method
method
With the engine fully cooled, remove the coolant cap.
Place the driptray of mat under the engine.
Depressurise the ball.
Place the rad cap centrally over the ball’s valve, and draw around it. This helps cutting, and later location.
Cut the ball leaving lots of overrun. You can always take more off if needed .
It just happened the ball’s valve is the same size as the filler neck (arrowed) .
[I cut the ball in half first. Now I have a basketball cap :rollyeyes:]………..
this is the kit as I used it:-
Clean the filler off with a rag.
Just to clarify, the Uno Turbo’s filler neck is located differently to most other Unos.
Disconnect the battery negative lead, and cover the battery with something which won’t conduce electricity. We don’t want any fires / explosions now do we? .
Place the pump on top of the covered battery, taking care not to scratch your paint .
I intended to use the jubilee clip to seal the ball’s valve to the filler neck. It turned out that the material is too thick. A tyre or ball inner tube may have been better. The pressure needed is low enough to hold in place by hand .
Moisten the ball’s valve underneath to aid sealing (I used spit ).
Fix or hold the contraption to the filler and get pumping (slowly). Take care not to over pressurise as you can easily do more damage. Listen for a hissing, indicating air loss. It took me a few goes to get it to seal. Would be easier to have an assistant pump or hold.
Check the drip tray / matt for leakage. I had some in two locations . You might not see any. In this case, it could be the radiator cap at fault, or an internal leak (eg head gasket).
I suppose you could have both an internal and external leak at the same time, especially if you have run the engine dry and warped your head.
If you see drips, get under the car with your eye protection on, and trace the drips. – sorted leak found Tad Darrrrrrrrrrr .
Thanks Ucof thanked for this post
Contents
<<  <    Next Page: Conclusion (Page 3 of 4)    >  >>
Old 07-05-2006   #1
Fixin UnoTurbo I sleeper
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Unhappy Cold Uno
Quote Originally Posted by Louie Bee
...I’m off to finish the job ....
O no i'm not... it's raining .
Louie Bee is offline Reply With Quote Quote
Old 07-05-2006   #2
now with added gold
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Cold Uno
lol,good guide though louie
Old 07-05-2006   #3
Jai
Banned
Jai's Avatar
Trader Rating: 6
Jai has donated!
Re: Detecting miniscule coolant leaks with a cold Uno
nicely done, kudos to the bee....
Jai is offline Reply With Quote Quote
Old 07-05-2006   #4
ben
The Boss
ben's Avatar
ben has donated!
ben is an honorary friend of the forum :)
King Pong Champion, e+Casino Blackjack Paper Champion, President vs Invaders Champion, Funny Clown vs Balloons Champion, Table Tennis 2.5D Champion
Taiwan
Nice one my friend - and well done for following all the "Guide" guidelines
my name is ben, i live in the east, i'm always working on the forum, i like pancakes.
need domains? cheap as chips - http://www.inetfx.net/domains.html
ben is offline Reply With Quote Quote
Old 09-05-2006   #5
Driving my Stilo
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
Excellent!
I'd never seen a Guide before.
So... break the suspense... where were the leaks?
-Alex
'03 Stilo Abarth Selespeed, '02 Spider V6, '00 Spider TS, '88 Uno Turbo i.e.
alexGS is offline Reply With Quote Quote
Old 09-05-2006   #6
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Arrow Cold Uno
Thnks Alex!
You’ve never seen your own guide ...
I must have forgot to ask when I nicked it .
The Leak,
Well after a rainy afternoon Sunday, and an evening fitting a vacuum advance diaphragm to the 1.0 IE, yesterday, this evening, I was under the MK2 Turbo once again.
All I can say it the engine and bay are looking cleaner . I haven’t got to the back yet . I will keep you all informed .
Regards All,
Louie Bee.
Comment
Search this Guide:
(G) What age Uno do you drive? Mk1 or Mk2? Chas Uno Uno 42 20-12-2007 17:59
(T) Uno Fire 999cc Cold running problems AliBarnett Uno 23 17-02-2006 11:55
(T) Clutch/Box Prob - uno won't go in gear when cold paz Uno 12 15-02-2006 16:06
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 00:15
(G) Uno turbo- poor cold start Citizen Smith Uno 3 18-09-2004 10:08
