The FIAT Forum
Go Back   The FIAT Forum > Guides > Tipo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Front brake pads. Removal and refitting.<!-- google_ad_section_end -->
Published by Hellcat
06-11-2005
Front brake pads/disc. Removal and refitting.
Tools you will need
  • trolley jack
  • 15mm combination spanner
  • 13mm socket or combination spanner
  • 12mm deep 6 side socket or combination spanner
  • file or wire brush
  • pair of axle stands
  • G-clamp
  • High temperature grease or anti-sieze compound.
Read First!
  • Before jacking up your car apply the handbrake firmly and chock the wheels.
  • Avoid getting grease on the disc or pad. If you contaminate the disc/pad clean them with brake cleaning fluid.
  • Check your brake fluid level. You are going to force the piston back into the caliper. If the fluid level is too high you will spill brake fluid all over the back of your engine.
  • Brake dust is nasty stuff. Do not blow it away with compressed air. Brush it off in a well ventilated area.
Contents
Article Tools
<< <    Next Page: Removing the brake pads (Page 1 of 4)    >  >>
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
