Styling What size tires and rims can you put on a Fiat Seciento Suite?
sipapito99
Germany
I want to put a set of aluminum rims and tires size 155/70R13 but my auto has 155/60/R13 would they work on my auto?help please.
yes but your speedo would be as acurate as throwing a rope with knots tied in it out the boot and counting how many knots leave the car in 10 secs
why you wanting to increase the tire wall size????? it will seriously mess up the handling too (will get cronic body roll when it gets twisty), normally people go wider and lower ie 175/50r13, or are you planning to go off roading in it????
you right it the rims I'm buying and they have the 155/70r13 tires but i hate to sound like an idiot what do you mean by those specs?
thank you in advance for all your help:slayer:
Tires:-
width = 155
wall hieght = 70 (% of the width)
diamitter = 13 (rim size)
Wheel Rim:;
pcd = 4x98 (4= number of studs and 98 is the mm between the stud hole on a diagnal)
offset = is how far off centre the part of the wheel that bolts to the hub so the closer to 0 the offset the more the wheels will stick out ie 18 will have the outer edge of the wheel outside the arch where as 50 will have the inside of the wheels sitting against the inner arch cinqs need IIRC between 32-38, someone correct me if i got anything wrong
this are the specs of the rims would they work?
Inch size: 13
Tyre Width: 155 Rim: 5.5J
Section: 70 Offset (ET): 38
Load Index: 75 Number of holes: 4
Speed Index: S: up 180 km / h PCD: 100
Tyre Manufacturer: Vredestein Rim Manufacturer: Rial
Vehicle type: Cars Rim Structure: one-piece
I guess that mean they wont work.what do you mean by wobbly bolts .sorry don't know much about tires and wheels.
Thank you so much for your time and help I'm about to bid on this wheel on e-bay.again thank you for all your help guys!:D
